short shift?
short shift?
hi all , mite b a bit gay on an l series but has any heard of a short shifter? made 1? dont want to chop the stick either. point me in the right direction. cheers ben
- Suby Wan Kenobi
- Suby Wan Kenobi
If you unbolt the shift lever you will see a bracket that the shift linlage joins to, there a 2 welds that hold it in position if you mark out where the hole is then make a mark about 5 mm higher so when you reweld the braket the hole will sit 5mm higher, you dont want to make position the bracket to high or it will foul on the transmission tunnel.
The long road ahead
The long road ahead
Thanks for that kenobiSuby Wan Kenobi wrote:If you unbolt the shift lever you will see a bracket that the shift linlage joins to, there a 2 welds that hold it in position if you mark out where the hole is then make a mark about 5 mm higher so when you reweld the braket the hole will sit 5mm higher, you dont want to make position the bracket to high or it will foul on the transmission tunnel.
