Just a couple of questions
Posted: Fri Mar 15, 2013 12:30 pm
by M0rpH
G'day forum members.
I'm slowly embarking on the EJ route to replace my EA82.
I have had my lifted l wagon for a while getting used to it and working out what mods i want to do.
It is my daily driver and regularly has varying loads (100kg-400kg) put in the back (there are no back seats).
One things that has been niggling at me...
Which way should the dipstick arrow be pointing on my ea82?
I get 2 different readings depending on whether it is pointed at the engine or away from it. :confused:
Also, are the genuine replacement front struts for an l series an oil shock or a gas shock?
I have been looking at the twin gas kyb's but if the genuine is an oil shock then i figure it would be better and last longer with a stiffer spring.
Any info would be great.
I have plenty more questions but these are the ones that come to mind at the moment.
Posted: Fri Mar 15, 2013 12:54 pm
by Alex
subaru use KYB as their shock supplier.
Id be replacing with KYB struts like we all have pretty much done. Run a KYB shock with king springs and youll get a nice, pretty stiff ride.
Posted: Fri Mar 15, 2013 1:15 pm
by Venom
Factory kyb are oil filled. Aftermarket are gas.
Posted: Fri Mar 15, 2013 3:44 pm
by RSR 555
Venom wrote:Factory kyb are oil filled. Aftermarket are gas.
+1.. The gas ones don't last as long but have a nicer ride IMO
From memory, the arrow points towards the engine, as I think the ring has a slight bend in it, making it tilt forward towards the radiator.
You'll be so happy once you get the EJ22 in there Scott. We need pics of the progress too ;)
Posted: Fri Mar 15, 2013 9:32 pm
by M0rpH
At the moment i have king springs all round and while my current shocks are not shagged i still don't feel the suspension is stiff enough for heavy corrugations or carrying a decent weight.
I have the luxury of constantly carrying heavy loads over some of adelaides more bumpy roads, but the nose gets fairly light when carrying 200kg+
Hopefully a little extra weight from an ej and perhaps a decent deep cycle battery may help that issue.
It doesn't bottom out too often (rear end) so perhaps i am being a little too picky overlooking the real world limitations of the car.
Posted: Sat Mar 16, 2013 7:49 am
by sven '2'
I had a custom rear set up in my L that sorted all of the issues that you are experiencing
Think it was a Mitsubishi shock, that was longer and therefore deleted the spacer. Even fully laden, the car sat flat.
Steve at Rising Sun has the recipe - recall it being a cheaper solution as well.
Posted: Sat Mar 16, 2013 9:11 am
by RSR 555
I don't think there is too much difference in the EA82 to EJ22 weight range. I've never really checked but the EJ22 is slightly narrower than the EA82, I wouldn't be surprised if the EJ is actually lighter??
Try the Honda or Mazda (can't remember which one) strut conversion that Jules (TOONGA) has done in his brumby. They are a adjustable coil-over design, so they can set to whatever weight you start loading the car up to. Jules grabed me a spare set and I'm going to trial them out in my L.
Posted: Thu Apr 11, 2013 5:42 pm
by M0rpH
Cheers for the reply's.
Well i have decided if i am going to have a lifted L series i may as well do it well.
I want the car to be fun, functional and last at least a few years of checking out this great land of Oz.
The suspension is going to have to wait a while cause i went shopping :twisted:
Now to clean up the shed :D
Posted: Fri Apr 12, 2013 10:08 am
by RSR 555
I'll be watching out for the updates as they progress
