Page 1 of 9
Is my WRX STi or not?
Posted: Fri Dec 28, 2012 1:19 pm
by Tomi
Hi everyone.
I am just wondering if my WRX is STi or not. How can I tell? There is an STi logo inside the dash cluster, there is an STi sticker on either side of the car, just in front of the front wheels. The is also the "i" badge on the front of the car which stands for STi I think. Anyway, the previous owner could of just added all of this to a normal WRX. The engine model is EJ20. Can anyone help me with this?
Posted: Fri Dec 28, 2012 1:30 pm
by nncoolg
Give Subaru a call and ask them to look up your VIN, they will tell you everything about it, even what colour it is
Posted: Fri Dec 28, 2012 1:39 pm
by Tomi
Where do I find the VIN?
Posted: Fri Dec 28, 2012 1:42 pm
by taza
Under the bonnet near the strut on a little silver plate..
by nncoolg
Firewall, near the brake booster.
Posted: Fri Dec 28, 2012 2:30 pm
by Tomi
Okay I found the VIN and have contacted Subaru about it. In the meantime, I have decoded the VIN using the car manual and it has come up with a 1.6L LX. This is clearly wrong as the car has turbo.
Posted: Fri Dec 28, 2012 2:32 pm
by Brumby Kid
I it 5 speed or 6 speed?
5 speed is just a standard WRX
6 speed is an STi.
Cheers Cam
Posted: Fri Dec 28, 2012 2:36 pm
by taza
Brumby Kid wrote:I it 5 speed or 6 speed?
6 speed is an STi.
I thought the older Bug Eye, Peanut and GC8 STI's were still 5 speed... Don't quote me on that though
Posted: Fri Dec 28, 2012 2:41 pm
by TOONGA
Tomi wrote:Okay I found the VIN and have contacted Subaru about it. In the meantime, I have decoded the VIN using the car manual and it has come up with a 1.6L LX. This is clearly wrong as the car has turbo.
Unless someone did a conversion to a 1.6l LX. you may have all of the STI parts in an LX body
Posted: Fri Dec 28, 2012 2:43 pm
by niterida
Yeah they didn't go 6 speed until later.
Sounds like a conversion
What is the code on the build plate (should be on the passenger side firewall I think) - Model type should read GC8xxxxx
Engine should be EJ20Gxxxx
Post them here and I will tell you if it is a WRX, STi or conversion.
Posted: Fri Dec 28, 2012 3:20 pm
by Brumby Kid
Nah bug eye models are 6spd.
All the "s" models have 6spd.
I'm not sure about the older "n" models.
The "n" models have vents in the bonnet left and right of the intake.
Cheers Cam
Posted: Fri Dec 28, 2012 3:29 pm
by niterida
I meant earlier STi's - as in GC8 models - are 5 speed
Posted: Fri Dec 28, 2012 4:05 pm
by Tomi
It is a 5 speed. The speedometer says you are going about 20 km/h over than you actually are. That could be a result of a conversion?
I can't find any engraving on the passenger side firewall. There is in large font, on the engine "EJ20". Nearby there is a smaller engraving that says "10BB22112". I'm not sure if this smaller engraving has anything to do with the question though.
Posted: Fri Dec 28, 2012 4:13 pm
by niterida
Info will be on a small silver tag pop riveted on to the car.
I think it is actually near the passenger side strut tower. Its about the size of a cigarette pack so you can't miss it.
Posted: Fri Dec 28, 2012 4:41 pm
by Tomi
I can see right next to the top of the strut tower, there are two small holes, that look just like there use to be pop rivets there. So whoever had this car before must of taken it off.
Posted: Fri Dec 28, 2012 5:04 pm
by niterida
Then the VIN/Chassis number is the only thing to go by - definitely sounds like a dodgy conversion or stolen/rebirthed maybe ?
Posted: Fri Dec 28, 2012 5:44 pm
niterida wrote:Then the VIN/Chassis number is the only thing to go by - definitely sounds like a dodgy conversion or stolen/rebirthed maybe ?
Or the other dodgy thing I've heard about where organised crime rings buy a legit car, steal one that's done up then strip out the stolen one putting all the good bits into the legit one - then sell it on and scrap the stolen one.
Really sorry to hear that your WRX isn't a factory unit. I guess you really can't be too careful these days
Posted: Fri Dec 28, 2012 6:19 pm
by Tomi
Is it that bad that it's a conversion? Everything in the car works fine. Also, why would someone spend so much money converting it? A whole new engine, plus making it an AWD. Seems very impractical.
Posted: Fri Dec 28, 2012 6:28 pm
by niterida
Conversion is not bad unless its done badly or you paid too much for it thinking it was a genuine WRX.
It is often cheaper to do a conversion than buy a WRX if you can do it yourself, which is why there are so many of them done.
Posted: Fri Dec 28, 2012 6:33 pm
by Tomi
It seems to be a good job, plus I didn't pay that much for it. Most WRX's were going for at least $9,000. This car was $6,000.
