Is my WRX STi or not?
Tomi
Post by Tomi » Fri Dec 28, 2012 1:19 pm
Hi everyone.
I am just wondering if my WRX is STi or not. How can I tell? There is an STi logo inside the dash cluster, there is an STi sticker on either side of the car, just in front of the front wheels. The is also the "i" badge on the front of the car which stands for STi I think. Anyway, the previous owner could of just added all of this to a normal WRX. The engine model is EJ20. Can anyone help me with this?
nncoolg
Post by nncoolg » Fri Dec 28, 2012 1:30 pm
Give Subaru a call and ask them to look up your VIN, they will tell you everything about it, even what colour it is ;)
# EA82 AWD 4EAT,
Tomi
Post by Tomi » Fri Dec 28, 2012 1:39 pm
Where do I find the VIN?
taza
Post by taza » Fri Dec 28, 2012 1:42 pm
Under the bonnet near the strut on a little silver plate..
nncoolg
Post by nncoolg » Fri Dec 28, 2012 1:42 pm
Firewall, near the brake booster.
# EA82 AWD 4EAT,
Tomi
Post by Tomi » Fri Dec 28, 2012 2:30 pm
Okay I found the VIN and have contacted Subaru about it. In the meantime, I have decoded the VIN using the car manual and it has come up with a 1.6L LX. This is clearly wrong as the car has turbo.
Brumby Kid
Post by Brumby Kid » Fri Dec 28, 2012 2:32 pm
I it 5 speed or 6 speed?
5 speed is just a standard WRX
6 speed is an STi.
Cheers Cam
Dads Car: 02 Impreza WRX STi
taza
Post by taza » Fri Dec 28, 2012 2:36 pm
Brumby Kid wrote:I it 5 speed or 6 speed?
6 speed is an STi.
I thought the older Bug Eye, Peanut and GC8 STI's were still 5 speed... Don't quote me on that though
Post by TOONGA » Fri Dec 28, 2012 2:41 pm
Tomi wrote:Okay I found the VIN and have contacted Subaru about it. In the meantime, I have decoded the VIN using the car manual and it has come up with a 1.6L LX. This is clearly wrong as the car has turbo.
Unless someone did a conversion to a 1.6l LX. you may have all of the STI parts in an LX body
niterida
Post by niterida » Fri Dec 28, 2012 2:43 pm
Yeah they didn't go 6 speed until later.
Sounds like a conversion :(
What is the code on the build plate (should be on the passenger side firewall I think) - Model type should read GC8xxxxx
Engine should be EJ20Gxxxx
Post them here and I will tell you if it is a WRX, STi or conversion.
Brumby Kid
Post by Brumby Kid » Fri Dec 28, 2012 3:20 pm
Nah bug eye models are 6spd.
All the "s" models have 6spd.
I'm not sure about the older "n" models.
The "n" models have vents in the bonnet left and right of the intake.
Cheers Cam
niterida
Post by niterida » Fri Dec 28, 2012 3:29 pm
I meant earlier STi's - as in GC8 models - are 5 speed
Tomi
Post by Tomi » Fri Dec 28, 2012 4:05 pm
It is a 5 speed. The speedometer says you are going about 20 km/h over than you actually are. That could be a result of a conversion?
I can't find any engraving on the passenger side firewall. There is in large font, on the engine "EJ20". Nearby there is a smaller engraving that says "10BB22112". I'm not sure if this smaller engraving has anything to do with the question though.
niterida
Post by niterida » Fri Dec 28, 2012 4:13 pm
Info will be on a small silver tag pop riveted on to the car.
I think it is actually near the passenger side strut tower. Its about the size of a cigarette pack so you can't miss it.
Tomi
Post by Tomi » Fri Dec 28, 2012 4:41 pm
I can see right next to the top of the strut tower, there are two small holes, that look just like there use to be pop rivets there. So whoever had this car before must of taken it off.
niterida
Post by niterida » Fri Dec 28, 2012 5:04 pm
Then the VIN/Chassis number is the only thing to go by - definitely sounds like a dodgy conversion or stolen/rebirthed maybe ?
Post by El_Freddo » Fri Dec 28, 2012 5:44 pm
niterida wrote:Then the VIN/Chassis number is the only thing to go by - definitely sounds like a dodgy conversion or stolen/rebirthed maybe ?
Or the other dodgy thing I've heard about where organised crime rings buy a legit car, steal one that's done up then strip out the stolen one putting all the good bits into the legit one - then sell it on and scrap the stolen one.
Really sorry to hear that your WRX isn't a factory unit. I guess you really can't be too careful these days :(
Tomi
Post by Tomi » Fri Dec 28, 2012 6:19 pm
Is it that bad that it's a conversion? Everything in the car works fine. Also, why would someone spend so much money converting it? A whole new engine, plus making it an AWD. Seems very impractical.
niterida
Post by niterida » Fri Dec 28, 2012 6:28 pm
Conversion is not bad unless its done badly or you paid too much for it thinking it was a genuine WRX.
It is often cheaper to do a conversion than buy a WRX if you can do it yourself, which is why there are so many of them done.
Tomi
Post by Tomi » Fri Dec 28, 2012 6:33 pm
It seems to be a good job, plus I didn't pay that much for it. Most WRX's were going for at least $9,000. This car was $6,000.
