need female
Posted: Fri Dec 07, 2012 2:41 am
Splined tube to fit M Y. And L series window winder crank or a kinked or cranked winder handle off anything to suit my l series short splined stump grfted to brumby window resuggestions welcome
Posted: Sat Dec 08, 2012 4:20 pm
Got a pic of the problem? I'm not really making sense of exactly what you're after - a window winder handle I'm guessing?!
Posted: Sat Dec 08, 2012 6:03 pm
Yes, a window winder handle not of MY or L but same splines and longer deep set splined drive section. Picture a spline poking out of door trim, only just and not enough to fir MY or L handle. An L winder bit has a 15mm shorter splined shaft than MY.
Like said in another post, tis sorted, but good to find handle for future problems
Posted: Sat Dec 08, 2012 6:09 pm
Glad you've already found a solution, what model vehicle did you get it from incase others happen to need to do the same?
Posted: Sat Dec 08, 2012 6:29 pm
Answer is not going to help as the donor for my 84 Brumby manual window was a 92? targa roofed, intermittent wiper switch (thinking factory or dealer optioned despite other swearings), manual window equipped Brumby so no longer a modification or conversion
Posted: Sat Dec 08, 2012 6:31 pm
thought I need a sort of splined tube to make my own winder handles out of, but mangled Brumby door released a pretty good, slightly bent from the RNA (rather nasty accident) - thanks to 1.00mm thick grinder cutting disc
there !! excuse #3 so far to have bought a dualsaw !! Price dropped to $198 at
W a while back
#1 was for cutting fibreglass safety tread mesh sheets, #2 deck cutting
