Page 1 of 2
Look what we found?
Posted: Sun Nov 18, 2012 4:48 pm
by Gannon
Posted: Sun Nov 18, 2012 4:53 pm
by Gannon
Posted: Sun Nov 18, 2012 5:10 pm
by thunder039
awesome find, there are some great parts there and a compliance plate.
so what are the plans? strip the good parts? or get it back on the road?
Posted: Sun Nov 18, 2012 5:11 pm
by nncoolg
sweet
Diode speculations
Posted: Sun Nov 18, 2012 8:57 pm
by pitrack_1
Gannon,
what do the diodes wire into?
1) Are they possibly voltage drop diodes for comparison/measurement purposes?
2) Are they something other than diodes, eg tranzorbs or zener protection diodes for HV protection e.g. from ignition system?
3) Reverse polarity protection?
Posted: Sun Nov 18, 2012 9:15 pm
by Kustomchris
Energy polarizers?
Posted: Sun Nov 18, 2012 9:19 pm
by sven '2'
that is hell of find - he did he locate such a gem?
Posted: Sun Nov 18, 2012 10:14 pm
by taza
Awesome! Great find alright
Height leveling suspension...? Sweet.
Does she run?
Posted: Mon Nov 19, 2012 5:19 am
by Gannon
Yeah it runs, the fuel pump was cactus, so we put a bit of fresh fuel in the fuel line between the firewall and the fuel rail and pressurised it with an air compressor and we had it started within about 5 min. Its been sitting for 4 years but the radiator is full of bright green coolant.
Tom only bought it for the rear discs and the LSD, and Im keeping the digi dash, trip computer and variable intermittent wipers, everything else is being parted out.
According to the symbols on the front of the blue covers, they are diodes, but physically they are not the normal black cylindrical type, more pea shaped. I'll trace the wires out to see where they go
Posted: Mon Nov 19, 2012 11:19 am
by guyph_01
Can i have the cruise control system if that like a separate loom and your not keeping it?
Posted: Mon Nov 19, 2012 4:20 pm
by Silverbullet
Fantastic find, I am envious of your electronic goodies
Gannon wrote:
Good luck figuring out what all this means
Posted: Mon Nov 19, 2012 4:37 pm
by Gannon
I dont care if I never use it, it just looks cool
Posted: Mon Nov 19, 2012 5:35 pm
by nncoolg
Next time your out at the car Gannon, grab the part number from the struts.
They look like 'MY' series struts as they are not offset, I wonder are they Koni inserts in an early model servicable strut?
Posted: Wed Nov 21, 2012 7:06 am
by tambox
Those diode sets are common on imported turbo looms.
I had used looms with those and I believe they are an electonic way of filtering several inputs to give the correct output for some dash lights. These were connected to options that were available on the overseas cars.
Similar to the door open light system.
Posted: Wed Nov 21, 2012 8:02 am
by Gannon
I had a better look at the diodes and traced the first one back to a factory relay that clicks when reverse is selected. I ran out of light and didn't get any further. Are they specific to digi dash vehicles?
Posted: Wed Nov 21, 2012 9:24 am
by guyph_01
I know the digital dash has a special fuel sensor and loom that goes to the fuel tank in the tank for it to work. Not sure about the rest.
Posted: Wed Nov 21, 2012 8:17 pm
by tambox
I have seen them in digital and analogue dashes. Sometimes with one set of diodes, others with two.
Ok some real info.
One of them is for a 4wd AT system.
The anodes (Bottom row with square corners) connect to
Stop light switch
Kickdown switch
wiper switch
wiper switch
int wiper relay
top row (angled corners) the single output goes to the AUTO 4WD RELAY.
Which automatically engages 4wd when any of the inputs are turned on.
Subaru, safety first:)
The other one??
I have never used them and either bypassed or removed them
Posted: Thu Nov 22, 2012 5:04 am
by Gannon
Yeah Nev has mentioned the fuel sender previously, any idea what makes it different?
Where did you find that info tambox? Do you have a FSM that covers this model?
Anyway I dont have an auto so the diodes are un-necessary
Posted: Thu Nov 22, 2012 7:11 am
by tambox
Ive got some hard copy OEM manuals for the L series.
They have helped me many times.
Posted: Thu Nov 22, 2012 10:41 pm
AWESOME find! What a Gem!
Is it really a dual range auto? How does this work and why are we only hearing about it now? Could be a test mule??
PICS PICS PICS (more! Please
