Who else is waiting for Sam's twin carb twin port ?
Post by steptoe » Thu Nov 01, 2012 9:28 pm
Sam aka Silverbullet, any idea of when this beast fires up ??
Post by sven '2' » Fri Nov 02, 2012 6:39 am
+1
Brumby Kid
Post by Brumby Kid » Fri Nov 02, 2012 6:56 am
Hurry up! I want my drag race!
Dads Car: 02 Impreza WRX STi
Post by sven '2' » Fri Nov 02, 2012 7:11 am
A go purple frock - they always win 'drag' races!
Post by Silverbullet » Fri Nov 02, 2012 4:52 pm
Woa didn't know I had an audience! :eek:
Sorry to disappoint, but it won't be this month (most likely) I kinda made a mistake in getting it rebuilt first, before the car :-? I feel a bit uncomfortable leaving it there untouched for so long. I was thinking of putting it in the bullet as is with the stock exhaust after I get my runaround going (that will be sooner than I thought now...wink wink) just to break the engine in, since I was forced to re-register the bullet a couple of weeks back. Might as well make use of it. So watch this space...kinda :rolleyes:
Probably will disappoint Phizinza as well, I promised him a ride before the end of the year :-|
Thanks for the motivation guys ;)
Post by El_Freddo » Sun Nov 04, 2012 3:03 pm
steptoe wrote:Sam aka Silverbullet, any idea of when this beast fires up ??
I too am keen about this!
Silverbullet wrote:Woa didn't know I had an audience! :eek:
Since when did you think this?? So long as others are posting on the forum you'll have an audience!
Now hurry up!
Post by Silverbullet » Sun Nov 04, 2012 3:38 pm
Well then it's settled; the engine is going in the un-restored bullet for the break in...hopefully the old gearbox is up to the job :|
Post by El_Freddo » Sun Nov 04, 2012 3:45 pm
Silverbullet wrote:Well then it's settled; the engine is going in the un-restored bullet for the break in...
Excellent! I love a bit of healthy peer pressure!
Silverbullet wrote:hopefully the old gearbox is up to the job :|
Since you won't be flogging it during the run in period I'm sure it'll be fine! If it does let go it's a good excuse for the L series gearbox swap :twisted:
phantomD
Post by phantomD » Mon Nov 05, 2012 12:56 pm
+1 :twisted::cool:
Post by Silverbullet » Tue Nov 06, 2012 2:59 pm
Hey here's phantomD, where's the thread asking for footage of his twins firing up? :o
Did you end up sorting your air cleaner box problem? is the engine running yet? From memory you had some interesting work done to yours.
Post by El_Freddo » Tue Nov 06, 2012 7:42 pm
Trying to change the topic! That's well below your standards SB!!
Post by steptoe » Tue Nov 06, 2012 8:39 pm
Man, when I started up my twins for the first time without the aircleaner on, sounded well, stereo for starters - um, sounded like an old 2.0 Kombi - but a horny one at that :D
Post by Silverbullet » Wed Nov 07, 2012 7:11 pm
El_Freddo wrote:Trying to change the topic! That's well below your standards SB!!
Was just curious is all :oops:
:lol:
phantomD
Post by phantomD » Fri Nov 09, 2012 4:58 pm
Mine is coming together nicely, should be ready by XMas all being well!! :D
And yes, something is afoot RE air cleaner...
Post by Silverbullet » Tue Dec 18, 2012 12:26 pm
You'll be pleased to know I removed the old engine today in a personal record slow time of 2.5 hours from running to sitting on the floor...well it has been more than 12 months since I did this last :o And I've got all the inlet and exhaust gaskets on the way, just need to find 4 carbie gaskets without buying 2 full rebuild kits. Was happy to find the larger diameter Y pipe will bolt straight up to the smaller rear exhaust section using the same gaskets, and I can adapt the smaller cylinder head-exhaust gaskets to fit quite happily. Using the smaller stock exhaust will probably restrict the engine a little, but I have nothing else and it's only for the break in anyway.
Watch this space :)
Post by El_Freddo » Tue Dec 18, 2012 1:10 pm
Silverbullet wrote:Watch this space :)
We already are!!!
Good to hear there's some movement on this project!
All the best with it!
Post by Silverbullet » Tue Dec 18, 2012 4:43 pm
Trying to install the new engine now, and the familiar frustration of trying to line the clutch up has driven me insane for the last 90 minutes...I've come back sore and beaten. My clutch alignment tool must be out my a fraction of a mm; doesn't work. Leaving the friction plate loose and tightening up the bolts through the starter hole; doesn't work. I think I got it in one time out of a dozen and when I reached for the nuts and bolts to hold it in it popped out again and the clutch plate fell down :evil::evil::evil:
There must be a trick to this...
Post by El_Freddo » Tue Dec 18, 2012 4:54 pm
Silverbullet wrote:There must be a trick to this...
Yeah there is - don't have the clutch plate that loose and patience is the key.
Best of luck with it!
Post by steptoe » Tue Dec 18, 2012 6:24 pm
Silverbullet wrote:Trying to install the new engine now, and the familiar frustration of trying to line the clutch up has driven me insane for the last 90 minutes...I've come back sore and beaten. My clutch alignment tool must be out my a fraction of a mm; doesn't work. Leaving the friction plate loose and tightening up the bolts through the starter hole; doesn't work. I think I got it in one time out of a dozen and when I reached for the nuts and bolts to hold it in it popped out again and the clutch plate fell down :evil::evil::evil:
Believe it or not, you are no Robinson Crusoe on this task, you go away, teach the neighbours kids new swear words, come back, fresh approach, mutter sweet nothings, change the angle of the dangle a tad, bolts within reach this time and whoompa, she slides in gently. And you wonder what went wrong the previous 90 minutes :D
Post by Silverbullet » Tue Dec 18, 2012 8:16 pm
Haha you're right Jonno I went away, had a rest and a cuppa and went out there to finish the job. It's in! Only a matter of time but however many times I've put an engine in it never gets easier...time to invest in a decent clutch alignment tool I think.
Now she's in it's just a matter of bolting up the stuff that goes on top and deciding which crossover pipe and hoses to use. Also, this engine has an EGR valve whereas the old engine doesn't (this car never had one) so could I simply remove it and bolt a blanking plate over the hole?
Getting it in and getting it running will be 2 completely different things, hopefully there's nothing too complicated to sort out in regards to emissions stuff.
