Surging Diagnosis
Surging Diagnosis
Hi All,
I am trying to diagnose a surging problem i am having with my gen2 liberty (EJ22 awd).
The surging is quite pronounced when the engine is under load, in particular when more throttle is given (estimate it would be above 50%). It has bouts of hesitation/surging.
I am thinking a few things and some other info on the net has given me some good starting points but am hoping to get some better diagnosis tips.
- I have cleaned the air flow sensor with air flow sensor cleaner, didnt seem to make much of a difference (it may have made a tiny difference but probably just in my head
- I have recently run some upper engine cleaner through it which didnt do anything
- I am trying out some fuel injector cleaner which is in my current tank of fuel, will let that run down and see if it does anything
- I gave the throttle body a spray as well as the connector and the connector for the air flow sensor as well.
- I have tried the battery unplug ECU reset
- I have had a look at the visible vacuum hoses and all look fine
None of the above seemed to give any obvious or noticeable results.
Does anyone have any suggestions?
There is no check engine light and the car appears to run fine when driven gently (easy on accelerator). This is leading me to believe it is an electronic related issue (or maybe the fuel pump is on its way out and cant handle the throughput at high load?)
I have recently added some radiator stop leak solution as my heater core appears to be giving off a bit of moisture. I am not sure if this could be related? (coolant temp sensor issues? - the temp reading is fine).
Any suggestions, etc. would be great.
I'd look at the relays under the dash - it's a common problem. Here's a link to a thread about using off the shelf replacement relays.
I'd also look at your fuel pump/system if the above doesn't fix it. Replace the fuel filter etc and if that doesn't change anything then look at the fuel pressure regulator and pump if you have to. If either of these don't check out then replace.
How many k's on the clock?
- Brumby Kid
Ok, not an expert with fuel injected cars but.
Have you checked for stored codes?
Fuel pump or dodgy fuel. Possible
I think it is probably your O2 sensor or something like it.
Others to confirm as stated above I'm no expert for FI cars.
But I would start by checking for codes.
Cheers Cam
Cheers Cam
Thanks for the speedy reply guys.
There is just under 150k on the clock and it was running fine until recently.
Looking at the thread i am not entirely sure if thats what my problem is as this bloke has issues at idle where as in my case it idles fine and is fine for a minimal throttle input (say less than 40% or so).
Does anyone know if it is posible to just purchase another relay from subaru? I am happy to just replace it if its cheap. or is it some ridiculous price?
- Brumby Kid
I have a feeling from the thread mentioned that it is quite expensive to replace which is why that method is used.gerzod wrote: Does anyone know if it is posible to just purchase another relay from subaru? I am happy to just replace it if its cheap. or is it some ridiculous price?
Not sure what price roughly though, worth checking.
Cheers Cam
Typical fuel filter signs. Try changing out the cheap small things first, then step up to the bigger things.
Fuel filter, spark plugs, leads etc etc.
Sent from my HTC Velocity 4G using Tapatalk 2
Thanks Alex,Alex wrote:Typical fuel filter signs. Try changing out the cheap small things first, then step up to the bigger things.
I might give the fuel filter a go. I did replace the spark plugs about 15-20k ago. Will pull them out and have a look and also test the spark plug lead resistance.
My gut is thats its still fuel related (either due to a mechanical issue such as clogged filter or failing fuel pump, or due to the control of fuel, via a sensor etc.).
If anyone has any other suggestions then feel free to chime in
Well, checked the spark plugs and they looked fine.
Just replaced the fuel filter, made no difference at all.
Tried another can of intake cleaner for good measure, no difference.
I will try flushing the cooling system and refilling (i can hear it sloshing away after using the stop leak, maybe it has created some clogs and there are air gaps in the system? I have been told these can cause surging issues due to the coolant temp sensor).
If that doesnt work then i think i will just take it to the mechanic
- scriptchip
What type of surging are we talking about ?
could it possible be the trans or gearbox ?
have you checked oils ? maybe the torque converter in a auto is suffered with high rpms,
so location of the surge may help.
~Subaru brumby 1990 - 14's , alloy bullbar , tow bar , 1/2inch rear diff bash plate. .... so far.
~ 2000 Outback - street project
Mothers vehicles.
2012 foz
1985 L series
Mothers vehicles.
2012 foz
1985 L series
Have you checked the MAF sensor?
That sensor is located on the airbox with square top.AlpineRaven wrote:Have you checked the MAF sensor?
If you're in Melbourne Ive got a couple.
Thanks All,
AR, I have checked and cleaned the MAF sensor with MAF sensor cleaner spray, which made no difference and It looked clean anyways. Thanks for the offer, I am in melbourne and if i need one I will be in contact
scriptchip, have checked oils etc, and the tranny is manual.
I am convinced it was fuel related as you could hear that rattling kind of sound (not quite engine knock) when the fuel mix is not right.
Strangely, I have refueled half a tank and it seems much better (still not quite right) so maybe it was the fuel. I will run this tank down then refuel with a full fresh tank to determine if it was the fuel quality, in which case i will be annoyed as i just wasted a weekend and some $$$ investigating haha.
Will be on holidays for a few weeks (yes i will be putting in some fuel stabiliser, dont want to add more complexity to the diagnosis) and will update when i get some more info.
Ive been there done that - cleaned and re-fitted it - cleaning didnt make any difference, so changed to another one yes it was dirty but it did improve.. worth a shot.gerzod wrote:Thanks All,
