Is it normal to hear fuel sloshing around?
- 2nd Hand Yank
After going on nearly empty for a long time and putting in a full tank, I now hear somewhat loud sloshing sounds when I come to a stop. It sounds like there is almost no baffling inside the L Series fuel tank.
Is this normal?
Is this normal?
- Silverbullet
There is no baffles inside the carby model L but you'd need to be lying down in the back of the car to hear fuel sloshing around?? Are you 100% sure it's fuel? and not some water container in the back??
- 2nd Hand Yank
Hahaha. I've got good ears mate.RSR 555 wrote:There is no baffles inside the carby model L but you'd need to be lying down in the back of the car to hear fuel sloshing around?? Are you 100% sure it's fuel? and not some water container in the back??
Nope. No water containers.
Glad to hear there's no baffles, so I know nothing's broken.
I've never heard it from memory. It could be that you're now paranoid about it. Check the doors and the rear wheel wells for water. If it's the rear wheel wells it'll be getting in through the holes in the side of the car that holds the plastic trim on the outside. Mine does that and since I've fixed the rust hole behind the rear wheels I always find them full
I'm yet to do anything about it.
- 2nd Hand Yank
Thanks Bennie!El_Freddo wrote:I've never heard it from memory. It could be that you're now paranoid about it. Check the doors and the rear wheel wells for water. If it's the rear wheel wells it'll be getting in through the holes in the side of the car that holds the plastic trim on the outside. Mine does that and since I've fixed the rust hole behind the rear wheels I always find them fullI'm yet to do anything about it.
I think water is the reason why my taillight fuse blew. My driverside taillight now fills up with water when it rains, since I used removalists to move from Perth to Townsville.
It appears that way Matt2nd Hand Yank wrote:Hahaha. I've got good ears mate.
I would get someone else to drive your car whilst you sit in the back and listen for 'sloshing', see if you can pin-point the area were this noise is coming from.
LOLsteptoe wrote:or you got fluid in the ear canal ? Turn up the stereo !
Very good advice here Bennie. May be worth checking out Matt.El_Freddo wrote:I've never heard it from memory. It could be that you're now paranoid about it. Check the doors and the rear wheel wells for water. If it's the rear wheel wells it'll be getting in through the holes in the side of the car that holds the plastic trim on the outside. Mine does that and since I've fixed the rust hole behind the rear wheels I always find them fullI'm yet to do anything about it.
- 2nd Hand Yank
- Silverbullet
I even hear it in the MY very, very occasionally and it's very very quiet. Has to be silent outside to hear it. I know it's not water behind my tail lights because I've seen inside the space back there, it's bone dry thankfully
The same can't be said however for the boot space
- Brumby Kid
In the STi,
Which I must say is very nice to drive and has a lot of pickup. (finally I was aloud to drive it
If I back it out of the shed, cut the engine but let it roll on the clutch.
When I pull the handbrake suddenly to stop it, I can hear fuel.
Also if I'm in the back, you can hear the fuel pump.
Cheers Cam
Cheers Cam
