Brake Fluid question ?
Brumby91
Post by Brumby91 » Sun Dec 04, 2011 2:10 pm
I have just done a rear disc conversion on the Brumby . I bought some Nulon brake fluid for it to bleed the brakes which is Super DOT 4!
The cap on the master cylinder says " Use only DOT3" !
Am I still able to use it?
Post by TOONGA » Sun Dec 04, 2011 2:24 pm
only use one type of fluid as each "DOT" is different, so don't mix dot 3 with dot 4 as they have different chemical components. If you are going to use "dot 4" get enough so you can flush the old fluid out of the system.
http://www.differencebetween.net/object ... ake-fluid/
http://www.superchevy.com/technical/cha ... index.html
Post by El_Freddo » Sun Dec 04, 2011 3:49 pm
You'll be fine to use the dot 4, the reason it says to use only dot 3 is that dot 4 wasn't around back in the day when your subi was built...
Dot 4, I've got no idea what the difference is. And Jules, you'll be very happy to know that I'm pretty sure I've mixed the two... Doesn't matter as she'll be getting a flush very soon, maybe a new master cylinder and if I can work out what I need/find the money some extended braided brake lines will be added as well.
Brumby91
Post by Brumby91 » Sun Dec 04, 2011 5:14 pm
Hey thanks Guys.. Flushed the whole system and used the DOT4... disc brakes on all 4 corners is freakin awesome !
Post by El_Freddo » Sun Dec 04, 2011 8:01 pm
brumby91 wrote:disc brakes on all 4 corners is freakin awesome !
They're worth the effort aren't they??
Imagine what the crossbred kit would be like!
Post by steptoe » Mon Dec 05, 2011 7:46 am
Some didn't think these disc rears were all that much better, but may have compared excellent drum rear to used disc rear end just before conversion - they are fantastic aren't they.
Agreed with Bennie DOT3 was likely best spec in 1980's !
Brumby91
Post by Brumby91 » Mon Dec 05, 2011 9:15 am
steptoe wrote:Some didn't think these disc rears were all that much better, but may have compared excellent drum rear to used disc rear end just before conversion - they are fantastic aren't they.
They are awesome .. Excellent pedal, great braking with little effort. Best mod so far
