Ways to mount my 3" aftermarket tach
Posted: Wed Nov 09, 2011 9:04 am
by 2nd Hand Yank
I'd like to put it on the steering column, but the parking light button is a bit in the way so...
I could place it behind that and need to cut a bit of the instrument cluster trim
or
I could relocate or delete this parking switch.
Thoughts?
Posted: Wed Nov 09, 2011 9:10 am
2nd Hand Yank wrote:Thoughts?
Start your own build thread and post all of these build ideas in there like what others have done in the member's rides section - add pictures with dummy fits etc... You can work out what to do as it's your build thread ;)
Toonga's build thread is an example of what to try and avoid unless you've got some time on your hands to read it all and respond if necessary :twisted:
Posted: Wed Nov 09, 2011 9:24 am
by TOONGA
Bennie, bennie, bennie... sighs all you need to do is read the first post :mrgreen:
Don't listen to him start a thread and have fun
you could mount it like this
or you could go mad like this
Posted: Wed Nov 09, 2011 9:48 am
by Luke82
i put mine here works well for me cos once its in 4wd u dnt need the light to tell you and mine has digital water temp so i dont need to see that either :) its screwed to the plastic at the top of the cluster.
By nibbleskibbles at 2011-11-08
Posted: Wed Nov 09, 2011 11:03 am
by Alex
Luke82 wrote:i put mine here works well for me cos once its in 4wd u dnt need the light to tell you and mine has digital water temp so i dont need to see that either :) its screwed to the plastic at the top of the cluster.
OHHHH JEEZ
i mounted mine like this once, the next day i blew it up trying to fudge a blue LED globe into it.
next time you think about changing your haircut second hand yank, you should run it by us for an opinion....
Posted: Wed Nov 09, 2011 10:16 pm
by 2nd Hand Yank
Nice. That's close to what I had in mind. :)
My tach is deep though, which is why it will either have to go offcentre like yours, or be on centre and I'd have to trim the dash, or relocate that parking switch...
I'm thinking relocate the parking switch, if it's easy enough.
My Gregories manual has nothing in it on how to properly remove trim panels.:???:
Posted: Wed Nov 09, 2011 10:19 pm
by 2nd Hand Yank
Alex wrote:OHHHH JEEZ
Nice pics. :)
Sarcasm? getting tired of my threads?
Why I ask is I might want to sell my L Series and I don't want to do very unpopular modifications. ;)
Posted: Wed Nov 09, 2011 10:37 pm
by Venom
To be reversible i would use some double sided tape to hold the tacho on so you/next owner can remove it easily, thats what i did. Nothing worse than looking at a second hand car with stupid little holes drilled in the dash/centre console.
