Page 63 of 67
Posted: Tue Jun 02, 2015 10:00 pm
by henpecked
Subydoug wrote:Nice Brumby mate, silver looks good on the old birds
. Sounds like the pup will have a good mentor.
Doug
if you like puppies and cattle dogs and like to see the pups progress some videos here
https://www.youtube.com/channel/UCMq7Ng ... fAiXskTc0g
Posted: Sun Jun 21, 2015 10:02 pm
by Subydoug
Got some goods off of ClassicJay, cheers again mate,
Front roo bar, Little bit better then the old one. Was a little bit twisted and still is but meh, will fend off the skip's just as well.
Also got his old Lib seats and installed them in the wagon. Orders of magnitude more comfy then the old MY seats. I ended up adapting the MY seat rails to the lib seats. Tight squeeze but they fit.
And a couple of MY's in the dunes,
Both are completely stock
Doug
Posted: Mon Jun 22, 2015 12:01 pm
by NachaLuva
Haha, yeah both stock
Both looking good but that hatch...
Posted: Sun Jul 05, 2015 8:55 pm
by dfoyl
Finally fixed the door sensor on the passenger side. Such a fiddly job, to remove the plastic shroud the seat needs to be come out. So 4 bolts, remove the seat, 7 screws and twist/squeeze/curse the plastic shroud until it pops out, then of course the 2 wires are jammed under the fuel lines (this was passenger side sensor), so very carefully pry the pipes out of their plastic clips one at a time and remove the old wires (at least they have QC lugs at the loom end), fit the new sensor in and feed the 2 wires through the inner door and squeeze them under the same fuel pipes, re-connect and test. Works fine, but now my driver side ones are only working intermittently. Re-assemble passenger side and will look at the drivers side another time (at least they don't throw a short circuit fault, they simply stay open circuit so no red light on the dash display).
Posted: Fri Jul 10, 2015 8:58 am
on the Brumby ? Instructions sound very familiar
More a switch than a sensor on these old girls. I have done a few , where it is best to suggest to blow the fuse first or disconnect the battery
and have bypassed your first few steps and just pulled switch out from outside, broke wires as the connectors were jammed in with something else other than fuel line - RHS , soldered in an L Series door switch, then needed to build up door side surface with the yellow washer from a hydroseal domestic tap washer with rivet. Really needs a bit more as when body flexes i get some courteous light flash on for me
Posted: Fri Jul 10, 2015 6:21 pm
by Clearwater99
Posted: Sat Jul 11, 2015 2:44 pm
by Tigger
Nice Clearwater99! Looking good
Just need a little lift to go with the new rubber
Posted: Sat Jul 11, 2015 5:57 pm
by NachaLuva
Very nice!
Did you do the lettering?
Tigger wrote:Just need a little lift to go with the new rubber
Yep
Posted: Sat Jul 11, 2015 7:40 pm
by dfoyl
Spent a few hours messing around with the hand brake "solution" put in by mechanic for XT6 5-stud conversion - ended up ripping out the entire Liberty hand-brake and putting the factory (MY) one back in, with the Liberty reverse-J handbrake line bracket bolted on. Now everything feels factory again, both sides pull at the same rate, but still needs a bit more engagement. Also fitted the factory rubber boot that goes around the gearbox levers that has been missing for several years and lets heat and oil vapour into the cabin. Painted up the centre console as it had varying degrees of sun-fade from the past 25 years.
Posted: Sat Jul 18, 2015 4:24 pm
by Silverbullet
The air filter on my Brum was waaaay overdue for a clean/replacement. Just today got around to buying the right stuff to clean and oil it. The amount of black gunk that came out was astonishing! And in the water when I rinsed it off.
Posted: Sat Jul 18, 2015 5:09 pm
by Phizinza
Are you sure your PCV valve is working correctly Sam?
I could have some something on my car today but yesterday I decided to make my finger the meat in a metal sandwich at work and had to put a hole through my nail to drain... Just typing with my left hand pains the finger. Looks like it will be another weekend of not much going on. Meanwhile my Brumby can't use it's second throat or the clutch slips...
Posted: Sat Jul 18, 2015 5:50 pm
by dfoyl
Fitted some 20mm spacers behind the Impreza 15" alloys on the Brumby:
(Left side is with spacer, right side without)
It may not be hella flush
, but looks a lot better than before and handling is noticeably improved.
Posted: Sat Jul 18, 2015 10:06 pm
by Silverbullet
They do look fantastic, just don't let the cops see dfoyl!
PCV valve should be working, it's only just over 2 years old. I think it had more to do with that filter being just as old as the PCV, but having never been cleaned or replaced
Posted: Mon Jul 20, 2015 9:01 pm
by dfoyl
Oddly enough, I was actually pulled over for a random breath test yesterday in the Brumby - didn't even remark on the car, and we had to wait 3 minutes while the random drug test result did its thing (first time I've been pulled over in about 6 months, and first time I've had the random drug test, which imho is pretty hopeless (drag a two pronged sensor over your tongue, then wait 3 minutes for the result). Doing this on a 2 lane road on a sunday afternoon isn't a great idea, the bank-back of cars must have been a mile long and this is 30-odd km's out of Melbourne, practically in the bush... I digress
The spacers you would have to look pretty thoroughly to spot as the wheels I chose (1994 WRX I found out today, I just thought they were basic Impreza wheels) don't show much of the hub/caliper. But I'm still looking for a legal set in a suitable offset (+25 offset isn't common, some VW's and Toyota's get down to around +38 but they aren't hub-centric obviously).
Job for this evening was pulling the struts to have the springs dropped, as the gap between top of the wheel and the fender is 5 inches. I have a set of spring clamps to collect from the PO, and then I can undo the nut and drop the springs in to Spicer springs - $66 to re-temper them to my nominated height (I'm thinking a 3" drop).
Posted: Tue Jul 21, 2015 9:07 am
some of the stats on drug testing drivers has been 20% hit, whereas booze testing about the 1% hit ! Three minutes and off you drive is better than some wasted dude causing grief to others and hours of road closure due to wasteds car and other body parts spread about the road, in turn contributing to PTST and its costs in turn. Glad you passed
The non ADR compliant spacers in Oz, could be better hidden if simply glued to the back of the rim and painted up to look like part of the rim, rather than the usual "see my shiny wheel spacers" look . Now, to test them out perhaps a defensive driver training course ?
Posted: Fri Jul 24, 2015 8:15 pm
by dfoyl
I don't have a problem with the test as-such, but it's fairly invasive and a poor location to do it - Canterbury Road is about the biggest (non-highway) road from the outer east suburbs all the way into Melbourne. And doing it for people heading out of town on a sunday afternoon ? They'd do a lot better on people coming back from fishing/camping in the opposite direction (plus a pub just 2 mins down the road).
Back on the Brumby, had the struts pulled out during the week so the springs could be dropped 3" after the 5-stud changeover - it was about 6" from top of wheel to edge of fender, which looked silly with low profile tyres. I thought of going a little further but strut travel might become an issue. I had Spicer Springs treat the springs - no cut coils! $50 cash was pretty reasonable I thought. Re-assembled it all this evening, so back on the road tomorrow and a front end alignment top of the list.
Posted: Wed Jul 29, 2015 7:25 pm
by NachaLuva
I painted the sump on the new engine!
Posted: Thu Jul 30, 2015 1:00 am
by Proton mouse
That's got to be the prettiest sump I've ever seen!!
Its totally sump-tuous and will give people sump-thing to talk about
Also love the way you keep your engine crane warm in the winter
Posted: Tue Aug 25, 2015 5:54 am
by mrwalker500
I redid the dodgy bog job on the bottom corner of the windscreen
Posted: Tue Aug 25, 2015 9:39 pm
by dfoyl
Found the ideal wheels to eliminate the spacers I am running on the Brumby - first gen Audi TT. +31mm offset on 7" wheels. Sourced and fitted one today and it is perfect - just inside the guards, clears the suspension, and a classic 5 spoke design. Even the centre cap looks the same diameter. Now to find the rest of a set, don't see many TT's at wreckers and I don't know any hairdressers who drive them
