Post by Gannon » Sat Jul 26, 2014 11:06 am
Looking at the wiring diagrams I figured it could be done, so a little bit of google searching found that somebody in the UK had done the same thing.
Should run better because the old coils were causing a misfire when on boost. If this coil fails a replacement is easy to come by because every EJ22 and EJ25 up to 1998 has one
Went this way over Bosch coils because this was easier and cheaper
steptoe wrote:That was pretty clever of you Gannon. Your idea or been done before ? Run any differently at all , or jus for cost and convenience?
Fuel pressure gauge ? Be hell easier if every efi had one of those - in the dash :) or at least a warning light off a pressure sensor if pressure dropped off. An oil pressure sender and gauge could do the job ????
Post by Gannon » Sun Jul 27, 2014 6:24 pm
Ive had a good run at doing things to my car, today I put a Gen2 Lib air box in
Post by NachaLuva » Mon Jul 28, 2014 9:59 am
You have been busy!
Subydoug
Post by Subydoug » Sat Aug 02, 2014 9:33 pm
Finally got around to swapping my wagon to EFI.
Gone for a few spins so far. Need to get my fuel tables dialed in.
Doug
Post by Gannon » Sun Aug 03, 2014 7:37 am
WTF!!!
Have you got some more detailed photos of what is going on there?
Have you got a build thread, I'd love to know the details of what you have done
nairobery
Post by nairobery » Sun Aug 03, 2014 12:17 pm
Subydoug that looks like rocket science , how did you do it. Am really interested. Great job
Sent from my MT2L03 using Tapatalk 2
Post by NachaLuva » Sun Aug 03, 2014 1:13 pm
Looks like more info is required lol ;)
Subydoug
Post by Subydoug » Sun Aug 03, 2014 1:59 pm
I plan on doing a build thread, but il get it all tuned up and running in its final configuration first as to not tell lies. Basically a homemade manifold holding a Harley V-twin throttle body. I built my own ecu to control it.
Doug
Post by TOONGA » Sun Aug 03, 2014 6:41 pm
Subydoug wrote:Finally got around to swapping my wagon to EFI.
Doug
Very nice Doug ... good to see that you got it to work :)
I might just have to visit to see it in reality :)
Jules
Post by El_Freddo » Sun Aug 03, 2014 8:01 pm
Awesome work Doug! Can't wait to see how well you get it running once it's been properly dialled in ;)
Nubaru
Post by Nubaru » Sun Aug 03, 2014 10:00 pm
you built your own electronic fuel injection board from scratch ? Very clever, arf, arf, arf !
Just how many wire connections coming from your efi box ?
So, after crawling to you, do you know how a knock sensor works say off a 4.0 I6 EF EL Falcon and whether it can be monitored simply with power in, DMM output ?
Brumby Kid
Post by Brumby Kid » Sun Aug 03, 2014 10:04 pm
Not that hard, Tweety did single point FI.
Just depends on how many sensors you want and if you can find/ get someone to write a decent code for you.
So whats that extra pulley for? Power steering?
Dads Car: 02 Impreza WRX STi
Bumpty
Post by Bumpty » Mon Aug 04, 2014 10:20 am
Trailered it to my mechanic..
Post by TOONGA » Mon Aug 04, 2014 8:23 pm
Brumby Kid wrote:Not that hard, Tweety did single point FI.
Tweety used an American sourced complete EA82 Subaru SPFI setup.
Doug has used a Harley throttle body and has done all the work himself, including the ECU.
The pulley is for the power steering.
Subydoug
Post by Subydoug » Mon Aug 04, 2014 8:36 pm
No worries Toonga, welcome around anytime.
Doug
Tweety
Post by Tweety » Mon Aug 04, 2014 10:31 pm
Yes, am going back to carboe from SPFI.
The SPFI ran just ok. Could be that both head gaskets were blown as to why it ran like a pig and just got me home one night then out came the engine.
So the SPFI system is for sale. Minus the manifold. If someone wanted to source a manifold from USA then the kit would be complete. Would make a good project.
System is $250 plus freight. or pick up Strathbogie. Includes spares like injector, throttle sensor etc.turn right at the black stump.
I suggest any buyers should not be novices, have some good electronic knowledge and be single...lol
Oh, by the way- took my manifold down to carrum Downs. A mate (engineer) is to build an adapter for the 38/38
Post by TOONGA » Sat Aug 09, 2014 4:30 pm
Today I did an oil change on jetcar shell 15w40 and one of these ebay oil filters I bought 6 for 16.80 + 4 dollars postage.
I did the same on PJ the brumby, I used gulf western 20w50 in PJ and the same oil filter. but ended up doing a power steering fluid change without wanting to :(
I have had a leak on the return line from the rack since I put the power steering in. Not a real problem but today I moved the line to get to a spark plug lead ( I was going to check the plugs) and the join came apart on the rack end. That's odd I thought, as the broken line dumped the power steering reservoir on the concrete, the EJ line was in good condition when I put it on nearly 3 years ago... oh wait nearly 3 years of constant abuse at my hands and hose clamps instead of a pressure clamp at the rack join ... nice combination. (remember I've got an MY rack and EJ PS pump)
I pulled the return line off and thankfully I had a length of fuel hose that was up to the challenge of running from the rack to the reservoir. I nearly pulled the dizzy out to get the flange nut located properly.I put a pressure clamp on the rack end and eventually got the line back onto the reservoir with another pressure clamp. a good dose of PS oil and I was back in business.
I will tell you how the oil filters go but for all intensive purposes they look just like a ryco unit inside.
nairobery
Equal exhaust headers
Post by nairobery » Wed Aug 13, 2014 9:27 pm
decide to try change my exhaust to straight through 2" pipe with equal headers...totally lost the boxer sound :(:(:(
Thought i felt like i gained a lil bit on gears 1 - 3, but onwards just felt like it lost power.
Going back to stock with 2" straight through pipe after the Y
Any advice will be highly appreciate
Post by El_Freddo » Sun Aug 17, 2014 12:01 am
nairobery wrote:decide to try change my exhaust to straight through 2" pipe with equal headers...totally lost the boxer sound :(:(:(
Equal length extractors will gain some kw at the flywheel but you will drop the subi beat - it's all about exhaust pulses. The factory Y pipe runs the left pulses into the right hand pulses hence the "thumping" sound.
By making things equal you effectively give the differing exhaust pulses a gap to fill and flow neatly like a set of gears meshing together.
So your H4 subi will now sound like a straight 4 cylinder...
2 inch from the cat back or the Y pipes back will be ample. It's more about the mufflers than the diameter. I've recently found out that 2 and a quarter inch on my EJ22 is too big for the engine for optimal performance :(
I've been hanging out with an awesome "old dude" that's been building exhausts for everything special since we were all in nappies...
Tigger
Post by Tigger » Sun Aug 17, 2014 7:22 pm
Finished installing the Dual Battery System for our Fridge and finished installing a new floor in the back of the Forester with some extra support for under the fridge - still yet to install the carpet - but that should be done during the week sometime.
Gibbo installed our Thermo Fan switch too :)
Also installed the Roof Basket extension along with clips on the side of it to hold a full length shovel.
Side awning should be installed during the week too - will post pictures once it has been done :)
