It sounded easy enough, so i gave it a go, the handbook said it holds over 7 litres but a typical drain only dropped around 2, so I got a 5 litre bottle...
I decided to drain it when cold as I figured most of the sediment would be at the bottom of the pan.
over 7 litres came out:eek: so I had to go for a little drive in the wife's car and get more, but at least I guess most of the old fluid came out!
So, now I know, drain it cold and you need a little over 7.5 litres
Most of which is probably common knowledge, but I thought I'd put it down anyway, it may prevent someone else being caught-short.
