Re my trike VW to ea81 conversion nearly completed.
My tacho is adjustable by a small screw behind it. is easy to do. Tacho is dependant on electrical feed.
After engine was installed the tacho was cearly out eg 100kph indicated 2000 rpm. with the VW it would be about 3100 rpm.
So have done some calculations and I ask any of you to confirm them so I can adjust it to be accurate when I get it back form the exhaust place this week.
Tyres are 275/60/r15. according to tyres calculator site has a circumference of 2.233 metres.
Tyre circumference 2.233 metres
Final drive is 3.67:1
Top gear (VW 3 speed full auto) is 1:1
At 2750 rpm
2750rpm/3.67 FD x 60 (mins) x 2.233 circum =100kph.
If this is correct then the formula could extend to the other 2 gears eg
2nd is 1.6:1
2750/3.67x60x2.233 divided by 1.6 = 63kph
1st is 2.65:1
2750/3.67x60x2,233 divided by 2.65 = 37kph
if you can please confirm
Recalibrate tacho needs maths confirmation
- Tweety
