'91 Brumby Driveshaft
Heya,
My '91 Brumby makes a click at the rate of once/revolution of the front left wheel. I'm thinking it's either the wheel bearing or the driveshaft, and i'm leaning towards driveshaft. So i am planning on getting a whole new driveshaft to replace it and DIY'ing it, which i've never done. If i was to buy a new shaft, what brand is reliable? I see a few on ebay but i'd be happy to go down the path of an auto parts store and get something quality that will last.
Is there anything I can do to confirm its the driveshaft? I've turned hard left and hard right but it doesn't seem to make any difference. It's done 330,000kms by the way... Cheers, Ron.
This may sound stupid, but make sure there isn't a rock or a nail stuck in your tyre.
Rotate your tyres and see if the clicking is still there. While you've got it jacked up, spin the tyre on the side that's making the noise, you probably won't hear the clicking but what you're listening for is a rumbling kind of sound, this will indicate that the bearings are on their way out or need to be re-packed. They should be quiet. Also check for bearing play by trying to twist the axis of the wheel mounted on the hub, if there's play their either dying, worn out or the castle nut needs to be tightened.
DIY isn't a hard job, just make sure you use jack stands and take your time with everything. The haynes manual says to take to a machine shop - just get a BFH and a block of wood etc to do the job
Repco
Bursons
All the auto stores will be able to get them for you.
Bursons
Ok, what's the trick to getting the shaft pulled through the steering knuckle and wheel bearings? The gregories mentions a knuckle shaft installing tool. I have packed it out with washers and tried to pull it through with the hub nut but now the drive shaft just spins. The old one pulled out easy... the new one is quite stubborn. Any ideas?
- TOONGA
I would say put it in gear and put the hand brake on but Im guessing you can't put the car in gear as the shaft is out
Put the wheel back on, lower the car down enough so that the wheel stops the hub from turning then tighten the nut up. (Im hoping you got sent the right shaft) This will pull the shaft through.
Ok, i did what you said and with a breaker bar I am struggling to move the nut. I have a spare steering knuckle and it will slide on and off the old drive shaft without any problem. It gets stuck on the new drive shaft though just like the one on the car. The splines match up to the gearbox and the hub and the measurement on the new drive shaft is only 0.03mm bigger in diameter where it is getting stuck.
I bought two CV's off ebay and they both appear not to fit. Seems like there is only a fraction of a beesdick in it or i am doing something wrong...
Anyway, i bought them off this mob http://sydneycvjoints.com.au/ if anyone has had any success with them let me know...
I think I (I know) I bought my ball joints off them and had similar beesdick problems and my digital calipers compared other brands to confirm the prescence of the boy bees apendage. A slight grind fixed my problems and etched that name in memory bank.
My trick has been to have the hub out and separated from everything so then when I have new CV shaft out, place shaft through hub and tap the new shaft on the solid ground and hub evenly works its way further onto the new shaft.
Needed to do this many times. Don't despair
