Ball Joint removal questions?
- Backyard_Brumby
Hi guys
Just trying to remove the ball joints out of the brumby so that I can both replace them as well as free the control arm so I can change the control arm bushings.
So far had no luck freeing it up....as you can see in the pick below I have removed all bolts etc but don't know how to remove it from here.
your help is really appreciated
http://imageshack.us/photo/my-images/82 ... 35001.jpg/
[SIGPIC][/SIGPIC]James
- littlewhiteute
- Backyard_Brumby
Thanks for the help guys, did end up getting them out...ending up putting a jack under and it obviously just moved them enough that when I dropped it back down and gave the control arm a hit they popped straight out...now just need to install the new ones...on initial look they seemed very marginally too big...as in they didn't slot straight back in. I did all this just to install new control arm bushings and now they look like they are too big as well.....wow I love ordering parts
balljoint remover tool is great
works like a dream, on later model cars they seem to sit ALOT tighter in the control arm.
- Backyard_Brumby
Not that I would assume anyone else would make this stupid mistake but I thought I would throw it out there as a bit of an oops story.
After removing the ball joints from the hub I was left with the control arm and the need to remove both the bushing and the ball joint. didn't quite have anything right to press out the ball joint and of course had no luck just banging on it. I was in quite a rush to get the bushes out. I had a washing machine tub (great for camp fires
) set up in the backyard and was just going to start the fire and chuck the whole arm in to burn out the bushing.....however i put the arm in completely overlooking the fact that the ball joint was still in there (obviously grease packed into a small metal capsule with extreme heat is not the best combo). It went fine for about ten minutes until one of them popped.....It was probably one of the loudest things I have ever heard in my life (considering I work around jet aircraft everyday is a pretty decent effort)....basically the metal casing shot off in shrapnel form...copped a couple bits to the arm but luckily got off very easily. I realise I am going to cop a lot of you are an idiot remarks but figured it was a easy oversight while trying to work quickly late in the afternoon
On the plus side , bushing burnt out....ball joint popped out easily and control arm was cleaned up nicely for a lick of paint
not yet any right to claim an entry in The Darwin Awards, not even close. Bloody hell, wouldna thought that would happen !!
We sadly lost an aquaintance in the last few weeks, who as a young apprentice was attempting to remove a bearing off an axle on a ten ton press, added oxy and effin BANG, shrappers got him and frq'd a nerve or two in his shoulder and essentially lost most use of his arm as a result. Alcohol was a good pain killer, led to more problems over the years and ....well, was found in his car in his shed
RIP Tim-Laden, you were WAY more than a work place injury statistic
