L Series brake booster in Brumby
Backyard_Brumby
Post by Backyard_Brumby » Wed Apr 27, 2011 9:50 pm
Hi guys,
Thanks to a very handy new acquaintance I managed to pick up a myriad of parts for the project today. One of which was an L series brake booster, just wondering if anyone has put one in a brumby and how easy it is / is it worth it.
In the brake system am also replacing
Master cylinder
Brake Lines
Rotors & Pads
Rear Shoes
just thought the bigger booster might finish it off nicely as at the moment you would be better off sticking your feet on the ground to slow the car as the brakes are that poor.
[SIGPIC][/SIGPIC]James :D
Post by steptoe » Wed Apr 27, 2011 10:37 pm
L Series booster I had to compare is just too big to go in the space a Brumby / MY has available without any serious surgery.
Have seen later booster in Brumby with some dodgy spacer
Post by steptoe » Wed Apr 27, 2011 10:40 pm
Uploaded with ImageShack.us
Post by steptoe » Wed Apr 27, 2011 10:42 pm
I said dodgy....
This thing was stopping an otherwise standard Brumby braked STi powered beast - 320kW @ 20 psi boost
Post by Gannon » Thu Apr 28, 2011 6:22 am
steptoe wrote:This thing was stopping an otherwise standard Brumby braked STi powered beast - 320kW @ 20 psi boost
I think you mean 320hp, because 320kW is roughly 430hp
Post by steptoe » Thu Apr 28, 2011 9:20 am
only repeat what I think I heard
Backyard_Brumby
Post by Backyard_Brumby » Thu Apr 28, 2011 6:14 pm
hmm interesting.It has a "spacer" on the firewall side and has apparently been on a brumby before....it looks like it should be alright, I will have a go when I pick up this new master cylinder. just wondering if it was a known swap...
and is it worth the effort?
Post by Gannon » Thu Apr 28, 2011 6:28 pm
I was under the impression that you could use a Liberty brake booster on an MY when going with a crossbred conversion, so why couldnt an L series booster be used?
Post by steptoe » Thu Apr 28, 2011 10:53 pm
its diameter !
Post by steptoe » Thu Apr 28, 2011 10:55 pm
just a thought now, i take back dodgy comment, that hose clamp aint a spacer, think it keeps heat guard in place
Dane
Post by Dane » Fri Apr 29, 2011 1:50 pm
I couldn't quite get the L series booster to fit. But I did the rest of what you've mentioned (braided lines?) and it was a massive improvement to brake feel.
rtcb65
Post by rtcb65 » Fri Apr 29, 2011 6:08 pm
Here is a pic of a liberty booster in a M.Y. / brumby . We fitted it up , only have to get the shaft to reach the pedal . That the only mod we did.
We have also fitted a L Series booster to a M.Y. wagon . It took alittle more work to get the shaft to reach the pedal . But it fitted.
rtcb65
Redneck Rick.
greywarden
Post by greywarden » Wed May 18, 2011 12:08 pm
Suparoo wrote:I was under the impression that you could use a Liberty brake booster on an MY when going with a crossbred conversion, so why couldnt an L series booster be used?
Dane wrote:I couldn't quite get the L series booster to fit. But I did the rest of what you've mentioned (braided lines?) and it was a massive improvement to brake feel.
after reading this thread i am still confuse if i will be liberty brake booster or L series brake booster :confused: btw where can i get one of this? please do not recommend me ebay i am also sick and tired of it. lol
Post by steptoe » Wed May 18, 2011 1:39 pm
The Lib seems to 'fit' . You are in Adelaide, lucky for you. Either Paul at Subareck or Steve at Rising Sun
Backyard_Brumby
Post by Backyard_Brumby » Wed May 18, 2011 6:17 pm
Turns out after all that, when we took the booster out it seems to be the exact same as the standard so I guess it is just the factory one. Now I am thinking about going and hunting down a lib booster though as i really want better braking
rtcb65 Any chance you have a pic or explanation of what you did as your mod for it to reach ?
cheers
