Can you guess what i've been up to?
Posted: Wed Apr 20, 2011 7:21 pm
by ScubyRoo
A few projects have finally come to an end. I'm about to head away for Easter, but couldn't help but share what i've been up to. I'll fill in all the full details when I get back with detailed write ups and photos, but for now you have to guess!
You have 4 clues...
#1
#2
#3
#4
The numbers "37" & "9"
Owen.
Posted: Wed Apr 20, 2011 7:59 pm
by TOONGA
didn't you blow up either a front diff in a gearbox or a rear diff ?
I remember that shot of the bits on the drail plug but couldn't find the original thread
perhaps a rebuilt box with modified hi-lo and lsd diff?
Posted: Wed Apr 20, 2011 9:29 pm
by Gannon
I think Toonga is on the money.
Clue 1 being the metal debris on the drain plug
Clue 2 is 2 gearsets and a diff stacked together
Clue 3 is no doubt a plastic hose joiner, but i have no idea what it has to do with the gearbox
Clue 4 is the number of teeth on the crown wheel and pinion wheel, which makes for a 4.111 diff ratio
Posted: Wed Apr 20, 2011 9:37 pm
by ScubyRoo
TOONGA wrote:didn't you blow up either a front diff in a gearbox or a rear diff ?
Rear diff blew up.
Suparoo wrote:I think Toonga is on the money.
1 - correct, from the old rear diff after the pinion gear was munched to about 20% of its orginal size
2- pick out a few more details, see if you can figure out what stage of the process it was!
3- see further hints below
4- Correct, the new ration is 4.11 :D
More hints, though you've all pretty much guessed it.
#5
#6
Posted: Wed Apr 20, 2011 9:57 pm
Damn I wish I got here earlier!
Got it: 4.11 diff ratio, L series low range and diff breathers.
Nice. Bet the outback goes well now - I presume you got the gear selector issue sorted??
I got my mates liberty going tonight - this arvo at 12 noon it didn't have an oil pump or radiator :D Runs very nice and 1st gear no longer clicks ;)
Good to hear someone in vic has got their gearbox project squared away!
Posted: Thu Apr 21, 2011 12:35 pm
by Subyroo
ScubyRoo wrote:
#6
That white fitting looks like a homemade diff breather.
P.S. Don't forget to put the tubing on.
:twisted: :twisted: :twisted: :twisted:
Posted: Fri Apr 29, 2011 7:21 pm
by ScubyRoo
Well after the car's first trip out bush, I can report a few things:
Diff breather wasn't tested (no water crossings), but the hose was clean so that's a good sign as there was lots of sand and mud.
Gearing with 4.11 and 215/70/15 tires is spot on, great to drive and fuel economy has improved... I wonder why they didn't make it 4.11 from factory...
With a VERY loaded car, I can take of in 2nd when in low range (yep, that's how low it is with the 4.11 and the ej25).
You should replace bearings when building a gearbox (see this thread).
Owen.
Posted: Fri Apr 29, 2011 8:40 pm
by RSR 555
ScubyRoo wrote:Gearing with 4.11 and 215/70/15 tires is spot on, great to drive and fuel economy has improved... I wonder why they didn't make it 4.11 from factory...
Owen.
Hey Owen.. what sort of RPM was your car doing in 5th gear at 100km/h?
Posted: Fri Apr 29, 2011 9:39 pm
by ScubyRoo
RSR 555 wrote:Hey Owen.. what sort of RPM was your car doing in 5th gear at 100km/h?
Off memory it was about 2800. The speedo is out by 3%, but by my calculations at 100km/h it should be 2750. Was about 3100 @ 110km/h.
I would describe the gearing as very similar to the stock feeling of an early liberty except the 2.5l is far more usable down low, especially with the 4.11. With the way it pulls, matching this box with a H6 or EJ257 with a small turbo would be incredible.
Posted: Sat Apr 30, 2011 9:25 am
by RSR 555
ScubyRoo wrote:Off memory it was about 2800. The speedo is out by 3%, but by my calculations at 100km/h it should be 2750. Was about 3100 @ 110km/h.
Ok thanks Owen.. I'm thinking my next gearbox build will have to be 4.11 :cool:
Posted: Sat Apr 30, 2011 10:19 pm
RSR 555 wrote:Ok thanks Owen.. I'm thinking my next gearbox build will have to be 4.11 :cool:
Of course you are! You know you want to!! I do!
Posted: Sat Apr 30, 2011 11:51 pm
by RSR 555
El_Freddo wrote:Of course you are! You know you want to!! I do!
Yeah.. thanks to you Bennie :p Damn you and your ideas :twisted::twisted: LOL
Posted: Sun May 01, 2011 1:36 pm
by ScubyRoo
Hi Paul,
If you plan on running larger than say 27.5" tires consider going 4.44. I'll put my 28s (215/70/16) on later this week and let you know what it feels like, although my guess is it'll feel slightly under-driven.
With 28s
4.44 with 0.852 5th is about 2850rpm @ 100kmph
4.11 with 0.852 5th is about 2650rpm @ 100kmph
With 27s
4.44 with 0.852 5th is about 2950rpm @ 100kmph
4.11 with 0.852 5th is about 2750rpm @ 100kmph
Owen.
Posted: Sun May 01, 2011 10:40 pm
by RSR 555
Hey Owen, I'm not sure what ratio my 5th gear is but I'm thinking I used the smallest one I had from the 3 boxes I took apart (I'm thinking it was from the L.Series box) and the tyres I'm using are 205/70R15 (pictured below)
Posted: Wed Jun 29, 2011 1:49 am
[quote="ScubyRoo"]If you plan on running larger than say 27.5" tires consider going 4.44. I'll put my 28s (215/70/16) on later this week and let you know what it feels like, although my guess is it'll feel slightly under-driven.
With 28s
With 27s
4.11 with 0.852 5th is about 2750rpm @ 100kmph/QUOTE]
So I guess you're running the 0.852 5th gear ratio :rolleyes: I reckon this is what I'm after for my 5th gear in the gearbox I'm looking at building. Just need to find it if I don't already have it in one of the gearboxes I've got for the build - three to be exact! Gen1 (I think) EJ AWD gearbox, L series PT4wd 3.7ratio gearbox and the L series AWD 3.7 ratio gearbox. EJ one for the casing, L PT for the low range and the last, well, you should all know why :twisted: Should make for a good combo with that fifth gear too.
