engine swap help
engine swap help
I'm going to need to do an engine swap out of a gl wagon in a couple of weeks, was wondering if there's anyone on the South side that would like to assist? As I've never done one before
Edit: qld Brisbane, Southside (forest lake)
- Backyard_Brumby
Its pretty basic, nothing to stress about. What you will need:
Jack
engine crank/hoist/2 sturdy mates with a good back each
10/12/14 and 17mm sockets/spanners
a workshop manual is good to have but not overly important, just there as a security blanket
What you need to do:
Remove battery.
Drain coolant and remove radiator and radiator hoses. Disconnect the heater hoses (back of engine on passenger's side). The heater hoses may be corroded and hard to remove.
Remove air filter box then cover the carbie with a cloth to stop things falling into it such as dirt etc.
If equipped with AC, remove mounting bolts for the AC compressor and tie off to the passenger's side of the engine bay out of the way.
Remove PS pump if equipped with powersteering. Tie pump off out of the way.
Disconnect engine wiring (clearish coloured plug, or blue in colour) and any vacuum hoses that lead to something on the body of the vehicle such as the brake booster vacuum hose. Mark all vacuum hoses so that you know where they go when you reinstall the engine.
Remove exhaust and engine mount nuts.
Now you should be ready to remove the 4 mounts to the gearbox - bolt/nut combination up top and stud/nut combination at the bottom of the gearbox bell-housing on both sides.
Lift engine a little to have engine mount studs clear their holes. Using the jack support the gearbox at this height as well.
The separation of the engine and gearbox can be a little difficult to start off. A rubber mallet can help to loosen things up a little. Once things start to move you can gently wiggle and pull the engine forward if pulling alone doesn't work.
Once the engine is free, raise it up and out of the engine bay then secure it on the floor or desired workbench and you're done
For first timer's I reckon this might take about 4 hours or so. Those who can do this in their sleep can knock it out in about half an hour
Best of luck
Jack
Remove battery.
Best of luck
- Backyard_Brumby
Once again Bennie is right on the spot,
I am now at the stage where I need the mates with strong backs. that is the only thing holding me back. but step for step that is exactly what I have done. haven't run into an issue yet.
would suggest getting some penetrating oil...pyroil make a good one. It saved me alot of time to give the stubborn bolts a soaking before having a crack
[SIGPIC][/SIGPIC]James
- sven '2'
El_Freddo wrote:Its pretty basic, nothing to stress about. What you will need:
Jack
Remove battery.
Best of luck
Good advice.
And once you are done
'Installation is the reverse of removal procedure'
Gotta love workshop manuals!!
And again, ensure you keep your fluids up...
- Backyard_Brumby
Mate cheers for that.. should be right as I have my old man to lend a hand but when your doing yours i would be more than happy to pop around and lend a hand. and if there is anything you need either tools or parts shoot me a pm and if i can help I would be more than willing. Just over in westlake so not far at all
No probs guys - I've done enough to remember that much from the top of my head! I had to remove stuff that wasn't relevant as it was including the gearbox when removing the engine
Take plenty of pics along the way - for old time's sake/sharing here/looking back on later after you've cooked your snags on the bbq or all those silly things you do along the way. An example would be the al-foil wrapped pies in the pot belly my mate and I did yesterday - we looked at the pic of those pies in the pot belly before they were cooked and both pissed ourselves laughing. Good times! Hope you have some too
