Page 1 of 2
The Plan for my vortex
Posted: Sun Oct 16, 2005 8:13 pm
by spaceage
Ok first off I hope i've posted this in the right section
secondly i'm posting this up here because i want your input if you think something is stupid or you know of a better way or company to do the job tell me, or if you have any other suggestins and ideas let me know. anywhere that i''m waiting on a quote i will update this post with the price when i get one.
Vortex Modifcation and repair plan
ASAP First to last
Fan Belts-To be purchased from “Repco” $51 for long belt and $25 for shorter one (9311 9999)
Dash fixed- Check “A-Part malaga” (9249 3555) see condition of stock or contact “classic and custom auto upholstery” (9495 1577) for quote on repairs
Clutch- http://www.autobrakeservice.com.au (9444 9911) waiting for quote
Suspension- KYB shocks to be sourced from “WA Suspensions” (9244 2211), King Springs from “Repco” (9311 9999) or “Wilkinson Suspension” (9370 2646)
Sunroof- Contact Prestige sunroofs (9317 1944) regarding new seal and roof repair
Seat Belts- Contact “Seat Belt Solutions” (9353 3932) for qoute on replacing all belts as some appear to be fraying slightly
Exhaust- http://www.mettamsmufflers.com.au ($280 for below system)
{Exhaust Recommendation:
Muffler: Straight Through (Sports performance)
Pipe Size: 2.25 inches ()
Cannon: 2.25 inch Stainless Steel (4 Inch Tip finish)}
Rims- http://www.atwtyresandmags.com.au ($1300 to $1700 for custom drilled blanks)
Not so important (yet)
Respray- worry about it after above completed
Engine rebuild or replacement- When the current one dies
Posted: Mon Oct 17, 2005 8:49 am
by Guest
Is it turbo or no?
Sounds like it will be like a new car when you're finished!
Something else you might look at doing is replacing the front balljoints and wheel bearings. You'd be suprised at what a difference this can make.
Posted: Mon Oct 17, 2005 9:32 am
by tim_81coupe
Those belt prices sound absolutely ridiculous. I work at a competing auto parts store and I bet I can get them and the King Springs a lot cheaper.
I'll send you a PM with contact info if you're interested.
Other than that you seem to have it on track, I've heard very good things about Prestige Sunroofs, also WA Suspensions seem to be the best in WA especially when it comes to Subarus.
Posted: Mon Oct 17, 2005 10:20 am
by Kev
I agree with Tim.
The long belt at $51 sounds more the price that Repco would charge for a timing belt. It may be a mistake.
I think that you can trust Tim. I have dealt with him before.
The picture of your Vortex looks like a nice clean car to start with. I think that it will be really good when you finish.
Kev
Posted: Mon Oct 17, 2005 8:33 pm
by spaceage
thanks for the replies, The exterior is clean (turtle wax colour cure lol)
the interior isnt so great faded cracked stained and etc
i got a qoute on the clutch today fitted, machining of flywheel and all parts supplied $685 This was from ABS, though I'm thinkngfor now i might just change the thrust bearing, it's really noisy and i've heard that can cause a bit of slipping as well, I also had a reply about the exhaust, full system as described in first post minus high flow cat for $280.
And i had a reply from atw about the rims, they have said the stud pattern is hard to find (which we all know) but can get some blanks drilled, he has asked what size i want, so i'm thinking either 16" or 17" (which is best) as i can get tyres that won't throw my speedo out and as it's my first car i don't want it to be cop bait
[/i]
Posted: Mon Oct 17, 2005 8:36 pm
by spaceage
oh yeah and i lost a hubcap on the way home from work today soi might have to move the rims up the list a bit lol :P
Cool
Posted: Mon Oct 17, 2005 10:06 pm
by coupe
Hi Mate
Glad your still perservering with the vortex.
Trust Tim he will find you a better price for those items.
how bad is the clutch slipping and have you adjusted out the free
play. Clutches arent that hard to do in fwd subies if the flywheel
doesnt need skimming then you can do it in a day plus parts.
To go to a 16 or 17 in a mag you will need a 45 or 50 profile to get
close to a normal speedo reading. How bad is the sun roof seal and
is it the outer edge or the roof itself.
Cheers Pete
Posted: Mon Oct 17, 2005 10:36 pm
by spaceage
it's not slipping badly, the biggest thing thats bugging me is the noise from the bearing, i used a tyre size calculator for the rims and it came up as 205/45R16 or 205/40R17 to keep the speedo within 1-2km of what it is now
the sun roof i think it was probably the drainage holes blocked, BUT i siliconed it shut a little while back, so this afternoon when i tried to pull it off to blow out the drainage holes after reading a post abou them i discovered i couldn't get it off :P lol but in saying that i didnt try really hard.
another thing pete does yourvortex have both fan beltson it or are you running with one as well???
Posted: Mon Oct 17, 2005 10:40 pm
by smoov
if its an NA subaru, you can get the catless header pipes (extractors?) through lukey. see your local carline mufflers. Mine cost $300 fitted.
I'll dig for a part number somewhere.
Posted: Mon Oct 17, 2005 11:01 pm
by spaceage
was there a big differance in power and sound with the lukey headers,
maybe i would be better off getting the whole lot through carline???
Posted: Mon Oct 17, 2005 11:19 pm
by smoov
very different sound (better)
difference wasn't earth shattering, but enough to feel it though. having said that, i did have cracks and fractures in my old header pipes (that also didnt have a cat)
my thumbs are up for it though. :D
Posted: Mon Oct 17, 2005 11:24 pm
by spaceage
cool thanks for that i'll look into it tomorrow
both
Posted: Mon Oct 17, 2005 11:43 pm
by coupe
Hi Mate i got both belts on
Keeping those drain holes clear solves a lot of probs.
U still go my number?
Cheers Pete
Posted: Mon Oct 17, 2005 11:46 pm
by spaceage
no sctuslly to be honest i lost it, it was scribbled on a bit of paper :oops: i will pm you with mine
Posted: Mon Oct 17, 2005 11:47 pm
by tim_81coupe
Or just get a set of EA81 headers :D
The Lukey ones I have seen are pressure bent, and no better than factory ones.
Posted: Mon Oct 17, 2005 11:49 pm
by spaceage
ea81 but my engine is the ea82, what would make th ea81 headers better???
Posted: Tue Oct 18, 2005 10:05 am
by BaronVonChickenPants
No cat converter, other than that they're the same.
Jordan.
Posted: Tue Oct 18, 2005 6:42 pm
by smoov
just older, and more prone to damage. chances are, they'll be fractured, like mine were.
EA81 = EA82 for headers. both are on and the same for headers.
Posted: Tue Oct 18, 2005 10:30 pm
by spaceage
I contacted carline regarding extractors, they toldme it was completely pointless because of the way the boxer engine is, or something like that he said if i take it in there and lift the bonnet he could show me why.
associated tyre wholesale has toldme 16 or 17 rims will be no problem the hardest thing is forme to choose which ones i want, ( and i gotta save enough for them on apprentice wages ) :P
so the plans coming along well
Posted: Tue Oct 18, 2005 10:56 pm
by smoov
spaceage wrote:I contacted carline regarding extractors, they toldme it was completely pointless because of the way the boxer engine is, or something like that he said if i take it in there and lift the bonnet he could show me why.
im keen to hear why. sounds like someone who doesnt know what they're talking about.
wheels? don't you have 4X140 stud pattern? Sorry to burst your bubble there, but this is a HUGE limiting factor as to what you can buy for your car, wheelwise. I havent seen anything bigger than a 15inch wheel for a 4x140. Your best bet would be to look into some wheel adaptors if you wish to fit 17s, or anything like that.
