knock sensor ?
Posted: Sun Feb 06, 2011 12:47 pm
by khanacross
hi guys ,, can i use a ej22 knock sensor on a ej25 ?
Posted: Sun Feb 06, 2011 2:03 pm
by Gannon
You probably can, i cant see that it will do any harm.
Posted: Sun Feb 06, 2011 4:56 pm
by khanacross
my thoughts as well ,it is only a microphone pretty much so thinking it will be ok ... thanks heaps ....khanacross
Posted: Sun Feb 06, 2011 5:38 pm
firstly look at the two - if fuji meant them to be interchangeable they'd be same plug, and if not the plug will be different.
Posted: Sun Feb 06, 2011 7:42 pm
by khanacross
yes the wiring plug is differant ,,both are just one single wire ,,i was just going to change end connectors ... any thoughts ?
Posted: Sun Feb 06, 2011 7:50 pm
by FujiFan
My thoughts, sounds like a good call. Are the two knock sensors the same make/manufacture? either way its just a tiny voltage generated by a piezo electric transducer, that is effectively what it does/is.
Posted: Sun Feb 06, 2011 7:54 pm
by khanacross
one is on a ej22 and other on a ej25 .. both single cam subaru's
Posted: Sun Feb 06, 2011 8:07 pm
by FujiFan
Look at it this way: Are the threads both the same - as in do the both fit into the block correctly? Just because the wiring conn is diff their function and most likely characteristics are the same as far as the ECU is concerned.
Noise generated by an engine that is "pinging" is much the same regardless of SOHC or DOHC or displacement. Feel free to correct me if I am wrong anybody.
Posted: Sun Feb 06, 2011 9:29 pm
by Gannon
There is no thread. A bolt goes through the sensor to attach it to the block
You are dead right, knock produces the same frequency in any engine. The knock sensor is a microphone tuned to that specific frequency.
Posted: Sun Feb 06, 2011 9:41 pm
by khanacross
i will try the ej22 one tomorrow ,will post progress on here ,let you know if it works ,,.. the pic that you (suparoo) put up is of a ej22 knock sensor ,the ej25 one has injecter style clip on wire on it ,.but should do same job once i change wire connector ,,hopefully save me some $$ as i do have a couple off 22 ones lying around . and i think even if it dont work ,its not going to do any harm trying (fingers crossed) . thanks for advice .. khanacross
Posted: Sun Feb 06, 2011 9:42 pm
by FujiFan
I see, forgive my ignorance as I was mentally picturing the older style sensors, think EA82, VG30, FJ20 and so on. Its been a trying day:)
Posted: Mon Feb 07, 2011 5:23 am
by Gannon
Like this?
I think the early ones with a pigtail only have one wire, and are grounded through the bolt, but the later ones have 2 wires. Just make sure you dont mix up the signal and ground
Posted: Mon Feb 07, 2011 9:29 am
by khanacross
yes thats the one
