99 outback fuel filter
Posted: Fri Feb 04, 2011 6:47 pm
by khanacross
hi all ,i did a search on here and found out the fuel filter is in the tank on this model ,,my question is ,is it possible to pull it out and clean it ? is it a bag style filter on the end of the pickup tube ?. ... problem i have with car is its very sluggish of the mark ,like its struggling for fuel ,i did check and replace the air cleaner which had a large hole in it from being sucked into throttle body ,,,i have just bought this car and i am just doing some service type maintainance ,,oils and filters ,,,maybe this will help my sluggish problem ... car is auto ... khanacross
Posted: Fri Feb 04, 2011 7:17 pm
by littlewhiteute
If the fuel filter was your problem causing sluggish acceleration, the engine would not rev up very well and probably no power whatsoever after 3000rpm.
If it has good power once you're moving, it won't be the fuel filter.
Posted: Fri Feb 04, 2011 7:22 pm
by khanacross
good piont ,thanks ,, just noticed "check engine" light is on aswell ... may need to look into that ,, thanks khanacross
Posted: Fri Feb 04, 2011 7:24 pm
by Gannon
In tank fuel filter is a compressed paper cartridge and is not cleanable.
If you air filter was sucked through, it must have been pretty dirty.
Posted: Fri Feb 04, 2011 8:36 pm
by khanacross
thanks suparoo,,, yes air filter was really dirty ,,,ive only owned this car for 3days ,so giving it a once over and service ,previous owners obviously didnt look after it ,,,as said its sluggish of line and check engine light is on ... any ideas ? thanks khanacross
ps ,car is same model as suparoo's in his pic ..... thanks
Posted: Fri Feb 04, 2011 8:51 pm
by Gannon
So is the check engine light still on?
Stick your head up under the dash and look for a pair of green plugs
Will look like this
Once you find them, plug them together and turn the ignition to 'ON'
Watch the Check Engine Light and count its flashes, both long and short.
Tell us and we can tell you what is wrong
Posted: Fri Feb 04, 2011 9:35 pm
by khanacross
really appreciate your help suparoo.... i just went out and tried this (green plugs) check engine light didnt flash
but the thermo fans would go on and off and fuel pump would go on and off ,(could hear them) ,,, am i doing something wrong ? thanks khanacross
Posted: Fri Feb 04, 2011 9:50 pm
by FujiFan
From what I've read its normal in this diag mode for thermo fans and f/pump to cycle on/off, but wait for confirmation on this.
Posted: Fri Feb 04, 2011 10:23 pm
by khanacross
yes fans and other things were cycling ,,, so do i just wait abit longer ? didnt i give it enought time ? about 5 mins ...
Posted: Sat Feb 05, 2011 6:39 am
by Gannon
Ok
Did you also see the black connectors there?
Make sure the green plugs are dis-connected and plug the black ones together.
Turn the ignition on and you should now have a code
Posted: Sat Feb 05, 2011 11:53 am
by khanacross
thanks heaps guys ,,i plugged the black wires together and started counting flashes , got two long and two short = 22 which i think is knock sensor ???? if so is the ej22 liberty's the same knock sensor?? (i have some spare ones of these) is it just a matter of replacing the sensor than start the car and go ? or do i now have to reset computer ? ,thanks heaps ..khanacross
Posted: Sat Feb 05, 2011 11:59 am
by littlewhiteute
I'd give the engine a Subaru upper engine clean, and possibly off car injector clean.
The carbon buildup in the combustion chamber increases the chance of spark knock, since the compression ratio is higher.
It also acts as a sponge, absorbing fuel that should be part of the combustion process, hence flat spots on acceleration etc.
Posted: Sat Feb 05, 2011 12:38 pm
by khanacross
ok ,found out ej22 is differant from ej25 ,damn .... so is the knock sensor a dealer only part or can we buy aftermarket ? how much money we talking here ? .. thanks
Posted: Sat Feb 05, 2011 1:05 pm
by Gannon
Here is an ebay one. I bought an o2 sensor from this seller a few months ago.
$120
www.ebay.com.au/SUBARU FORESTER IMPREZA LIBERTY OUTBACK KNOCK SENSOR
Posted: Sat Feb 05, 2011 4:10 pm
by khanacross
huge thanks to suparoo and little white ute ,, thanks guys ... khanacross
