99 outback gearbox
99 outback gearbox
Hi all I need to change my 99 outback from an auto to a man dule range, can anyone tell me where i can get a good gear box and how much i should be paying, also does the forester gearboxes fit into these diffs, any feed back would be great Ta
- d_generate
I would imagine Foz would be identical, you'll need a manual tail shaft, pedal box and you have to change some of your wiring.
Your old auto tail shaft will be worth money as anyone putting a 6 speed into a Liberty will need it.
If you have room sometimes the cheapest option is to buy a wreck from Pickles or Fowles....especially next week as the cars go very cheap before Xmas, I bought 3 the same time last year for half what would be the normal going rate.
dont forget the ratio differences, Gen 3 Outback has 4.11 diff where abouts dual range is 3.9 so you'll need to change the rear diff.
The chepest and easiest way would be sell it and buy on already done!d_generate wrote: If you have room sometimes the cheapest option is to buy a wreck from Pickles or Fowles....especially next week as the cars go very cheap before Xmas,
87 targa brumby (Neglected),
+ others.
+ others.
