Brumby prop. shaft.
Brumby prop. shaft.
Loose universal joints are shitting me to tears... can i drive my beast with the prop shaft removed..?
U.j replace
Can u replace the uni joints in a 92 brumby?
yep, you can buy them in shops
"UNDERSTEER" is when you hit the fence with the front of the car.
"OVERSTEER" is when you hit the fence with the rear of the car.
"HORSEPOWER" is how fast you hit the fence.
"TORQUE" is how far you take the fence with you.
If it works, pull it apart to see why.- RSR 555
Some can be but you'll need to look at your prop shaft. Were the uni-joint cup is there needs to be a c-clip on the inside. If unsure, I'd call RGM and get a quote.. you might be surprised
Oil leak.
It appears that the brumby tailshaft is different to the L series. Mine has a two piece shaft with a retained spigot and flange on the gearbox, so the rear shaft can be removed and still driven. Anyone remember the dark ages when most parts interchanged between models?
How much oil do you have in your gearbox??? I'd definitely be raising the rear of the car to remove the prop shaft rather than the front, no oil will come out when you do thiskilo wrote:toonga is spot on, best fix is to replace uni joints. cheap n easy to do, jus remember you will need to replace gearbox oil when you finish the job cause you will loose the lot when you remove the shaft.
And the L series two piece tail shaft is very handy at times for removing the rear diff if you ever need to - like when you weld it up
