carby help
- shazdave67
carby help
Hi fellas, i pulled my carby apart today and 2 ball bearins and another thing came out when i tipped it upsie down, i know one of them goes in the plunger and i think the weight does to but not sure about the other ball.. Cant find help on net anywhere,, help please.. Dave
- littlewhiteute
Dave,
I'll take a educated guess, all to do with accelerator pump circuit.
One ball bearing and weight is the "outlet check valve", other ball bearing is the "inlet check valve" at the base of the pump well under the spring.
One end of the spring is made to retain the ball in the base of the pump well.
Gary
Gary
- shazdave67
Thanks boys couldent find the thread only new,, think ive got it sorted but im sure they have the wrong spring in the acc, pump? The weight has no place for it to sit in it if you know what i mean? And one ball is bigger then the other, so what one goes where? Have a carby kit but it dont show the weight or the balls..
- shazdave67
