vacuum sources for turboed engines ??
In planning my turbo conversion, my thinking has hit a stumbling block
If the turbo pressurises the inlet manifold at times vacuum operated bits need consideration don't they ?
Firstly , vacuum advance is most likely disconnected, so no worries.
vacuum brake booster holds vacuum for one operation at least, and the Subaru vacuum operated heater controls...
And what do you do to protect these from boost pressure popping things off or undoing their intended functions.
Another vacuum reliant item on me Brumby is cruise control
The LPG safety cut out is also vacuuum operated, so an electric box will take care of the fuel supply
My limited experience with turbos is with Diesels and they don't have manifold vacuum at all , rather a vac pump on the back of the alternator or completely separate so those conversions don't need any attention.
So what do you do with petrol or gas converting to turbo ??
The brake booster hose in turbo cars has a one way valve in the line. You would normally be off the throttle if seriously braking anyway, so there'll be plenty of vacuum in that state.
I'm not sure what happens with the vacuum powered vents and stuff - I haven't found a valve in the system, but maybe there is one.
The distributor in the older stlye cars has both advance and retard, so there's no issue there.
- tim_81coupe
As Craigus said, one way valves for your heater controls and brake booster. You will need to add the valve for the vents.
You could also hook vacuum items up pre-turbo, plenty of vacuum there when the revs get up, not so much down low though.
The PCV system on my EJ20G runs off pre-turbo suction.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
- Suby Wan Kenobi
- Suby Wan Kenobi
- Suby Wan Kenobi
