Gearbox Options
Posted: Wed Nov 03, 2010 10:00 pm
by brumbydan
Hi all,
just wondering what my options are for replaceing the original dual range box in the Brumby. I need to expand the life span of the Brumby without spending too much time or money.
Dan
Posted: Wed Nov 03, 2010 10:03 pm
by spike
what are you trying to extend the life span of??
if its the engine, than a 5 speed
if its anything else find and pay the money for a awd DR
Posted: Wed Nov 03, 2010 10:06 pm
by brumbydan
You would know the model of the 5 speed box?
Posted: Wed Nov 03, 2010 10:30 pm
by spike
dont think they came in the brumby
check in the conversions and the gbox section
Posted: Thu Nov 04, 2010 1:07 am
by RSR 555
The Brumbys and M.Y. wagons were only available with the 4 speed gearbox (single or dual range) if you want anything else it will need to be a conversion. The L.Series 5 Speed dual range is a faily common conversion and you'll get plenty of help from this website :) There are plenty of other options but if you're working to a small budget then stick with the L.Series box. When the budget becomes bigger and you would like to extend the Brumbys life (engine life) have a look at fitting the EJ22 from a Liberty.. another common conversion.
Paul
Posted: Sat Nov 06, 2010 8:44 pm
by AlpineRaven
RSR 555 wrote:The Brumbys and M.Y. wagons were only available with the 4 speed gearbox (single or dual range) if you want anything else it will need to be a conversion. The L.Series 5 Speed dual range is a faily common conversion and you'll get plenty of help from this website :) There are plenty of other options but if you're working to a small budget then stick with the L.Series box. When the budget becomes bigger and you would like to extend the Brumbys life (engine life) have a look at fitting the EJ22 from a Liberty.. another common conversion.
Paul
1+ You also could use Liberty/Forester/Impreza's AWD D/R box behind EA81.
