EA82 front pulley choices
Posted: Wed Oct 06, 2010 11:22 am
Just curious if anyone has tinkered with changing the front pulley between the plain old metal one and the other with rubber bonded harmonic balancer style of the efi and later carb versions.
The plain old metal one will never fall apart like the rubber bonded ones but curious to know if any benefit found or even the theory behind the dfference would not hurt.
Found some to have small roll pins to locate in one of the many holes in timng belt drive sprocket, also a fat pin that must locate in the bigger keyway slot of the same drive pulley. bashed a pn from a dud multi rib balancer into a plain metal one, found the pins top side needed a flat filed onto it to fit snugly into drive sprocket
