Going with an idea that popped into my head a few weeks ago, I made up a rough prototype to check feasability and to work out measurements etc...
Because the front shafts (the splined bit) are bigger than the rear, it's not as simple as just bolting some spare front hubs onto the rear. What I went with, was cutting off the drum section of the rear hub, machine the seating surface into the back of it for a front disc to nestle into, drill and countersink the bolt holes and end up with with something that fits properly and has plenty of clearance. The caliper will simply bolt to a heavy mounting plate that will secure to the backing plate mounting on the suspnsion arm.
As well as beefing up the rear brakes, I'm going to look at how easily I can mount an extra set of calipers on the front discs, with the aim of increasing clamping power and contact area on the disc.
Oh, and the other BIG advantage of using the standard calipers (well, the ventilated ones) on the rear, is I can install an extra handbrake lever and have front AND rear handbrakes for holding on steep slopes, depending on which end is uphill...
