running without covers
gemery10
Post by gemery10 » Fri Mar 17, 2006 4:21 pm
Looking on USMB I noticed they mostly run without timing covers. Anyone here doing that. What about in sand?
BlackMale
Post by BlackMale » Fri Mar 17, 2006 4:52 pm
8O no1. I have never ever seen/know is doing that.
Post by AlpineRaven » Fri Mar 17, 2006 6:26 pm
I wouldn't do it!!!!!!!!
Reason - oil, dust, gravel, stone, sand, mud and water will go where the timing belt is... will cause pre-mature wear on the belt & bearings as well, there is NO real good reason to have with or without timing belt cover for performance reasons. Fair enough if you have broken cover but get it fixed ASAP.
EDIT: If you get a stone caught in the belt could cause the belt to slip/jump or fall off or damage something!
Also its a deflect issue if you got caught.
gemery10
Post by gemery10 » Fri Mar 17, 2006 10:24 pm
thats what I first thought but...
Pros
Easy replacement of belts, water/oil pump, idler/tensioners, oil and water don't get trapped in there
Cons
Idlers could get more water in there, belt could jump off(who cares on ea82 as non-interference anyway!), sand could really cause all sorts off havock, bit more dangerous for catching stuff when you are working on it.
so...
The yanks have been doing this for ages through all 4wd conditions except sand from what I can see, with only a couple of failures due to a rock catching or something. They reckon the spinning deflects anything that can cause probs, and you have better access to lubricate idlers, tensioners etc,
I would never do it on interference engines but it is mighty tempting on L series. Any opinions
tim_81coupe
Post by tim_81coupe » Sat Mar 18, 2006 3:04 am
It's only a couple of bolts. Come on.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
MUDRAT
Post by MUDRAT » Sat Mar 18, 2006 4:26 am
Hmmm . . . must say I'm not too fussed on the idea. The negatives seem to far outweigh the benifits.
