Bearings gone again
Posted: Fri Jul 16, 2010 5:24 am
Hi all, I'm a newbie to this forum and thought I'd introduce myself before I ask questions, apologies for the length of my first post too!
I've got a 1989 L-Series Sportswagon, I've had it for 7 years and for the first 4 years it spent lots of time on sand as I'm a keen beach fisho. I fitted 14" sunraysia used rims with 195/65/14 tyres which worked well on the sand, it also looked the part;). It also got a look in on some swampy tracks around where I live and it tested my driving skills as some of the ruts caused by big fourbies carved out knee deep gutters. It's all about wheel placement when you've got a car that sits low on standard suspension I learned. This car taught me heaps about offroad driving and I surprised lots of people in bigger fourbies when I stayed with them on local tracks and the beaches. It just romps over soft sand too with 15lbs psi in them.
However it was taken off the road 3 years ago and put back over a year ago when my eldest son got his P's, I refitted the standard 13" rims as tyres are cheaper for them. It spent all of the year on black-top. He's now moved to Sydney to go to uni and no longer needs a car. So my second son is just about to get his Ps anytime now and has taken over, it will also be his first car. He's a high school student, more outdoorsy, a surfer and is keen to do some off road exploring with it which I think is great. He remembers its capabilites.
He gave it an immaculate detailing, fitted a new stereo and repainted the old Sunraysia's and put 2 new 185/75/14 tyres on it, 2 more to go on later. All on his earning from working part-time at Woolies. The car looks fantastic and actually sits higher with this profile than the 195/65/14s. I'm going to ask him to join this forum, hope he does he might learn a few things. He's keen with the tools too.
NOW THE MECHANICAL QUESTIONS!
I'm a hands-on backyard mechanic and I've always done my own maintenance and repairs on this and all my/family cars. I've got lots of tools and not afraid to use 'em.
BEARINGS:
The wheel bearings are becoming an issue again! I'm confused with the torque required for the L-Series and there seems to be conflicting reports on this and other Subie forums. I, like many others, don't have a torque wrench that reachs the required spec so use the pipe on the breaker bar trick and turn-till-you-fart method.
But this seems to have killed one of the new rear bearings as the nut was constantly becoming loose. It eventually died in 20,000klm and chewed out the hub in the swing arm groove...yes son No.1 did not tell me it was making noises to warn me when it got real bad.
The bearings for the rear are freakin' expensive as they are the complete hub kit as you know, and yes they have 2 tapered roller bearings inside side. The original spec in the Haynes discusses perhaps the older style of bearing. Torquing tapered bearings till you fart has always been avoided when I fiddle with motorcycle bearings. Tighten 'em too much and you can actually dent the races therefore are cactus. So why are they being recommended in the Subie's application especially on something that rotates continuosly at speed?
So, PLEASE tell me, what is the actual torquing spec for front and rear wheel bearings.
CV JOINTS:
Front right was replaced with new + new bearings and is OK. I transferred the old right CV to the left as it was in better condition. However the new bearings won't fit the old shaft!
They are 6207s and it stumped me why it wouldn't fit (inner diameter too small and was marking the shaft). So I refitted the old bearings. It's done around 7,000k's this way and something is now going wrong...to be expected though as they are older parts. I managed to torque it up a bit more and get enough rotation to use the next split pin hole in the axle. Sort of worked for about a week of short hops. But now....aaargh...
Tell me, what is the 'squelching' noise I've been hearing? I did get this noise on the rear bearing which collapsed. But the front? I don't think it is a bearing noise and the CV seems OK as it doesn't *clack-clack* at full lock in either direction. The squelch noise seems to follow each tyre rotation and increases with rapidity as speeds rise, just like the back bearing did. It seems to stop when the clutch is disengaged which must be a clue but I can't figure it out. Is this a bearing problem in disguise or is it the inner CV joint? What is my next plan of attack? I definately is not brake related.
Any help would be appreciated.
Thanks in advance. Pic to follow.
BEARINGS:
CV JOINTS:
