liberty ski fx 1996 ecu
Posted: Fri Jun 04, 2010 5:50 pm
by monkers
hi,
iv got a liberty skifx lx 1996 and im attempting to set up a centrafuse system in it, i was wondering where the ecu is and does it have obd ii?
Posted: Fri Jun 04, 2010 6:36 pm
by Gannon
Im assuming that Centrafuse is a program you install on a mobile pc for playing music and video in your car.
The ECU is either up beside the steering column or under the carpet in the front of the passenger side foot well
OBDII wasnt introduced into non turbo Subaru's in Australia until about 2003 (i think turbo models got it around 1998 ) Before that it was just SSM (subaru select monitor) which is a Subaru based data code based on TTL serial data transmission.
Posted: Fri Jun 04, 2010 9:44 pm
by AlpineRaven
It's located under the carpet on passgener's footwell. And it doesn't have OBDII
Posted: Fri Jun 04, 2010 10:19 pm
by vincentvega
I sell data cables for these early ecu's. I also run a PC in my car.
the best you are going to do software wise is
http://www.vwrx.com
head on over to
http://www.rslibertyclub.org forums and search for my username and also "Impakt"
I sell data cables, he sells stand alone display units
Posted: Fri Jun 04, 2010 10:21 pm
by monkers
thanx for the help guys really appreciate it
Posted: Fri Jun 04, 2010 10:23 pm
by monkers
keep getting a 404 error on
http://www.rslibertyclub.org is it down?
[edit]
works now..
Posted: Sat Jun 05, 2010 1:46 am
by monkers
where exactly under the carpet is it? i pulled up the front part under the dash and there didnt appear to be any plugs. also what kind of plug am i looking for, im pretty new to this, my skills are more computer based, and theres not a lot of information straight up on SSM
Posted: Sat Jun 05, 2010 7:40 am
by Gannon
Posted: Sat Jun 05, 2010 7:41 am
by AlpineRaven
monkers wrote:where exactly under the carpet is it? i pulled up the front part under the dash and there didnt appear to be any plugs. also what kind of plug am i looking for, im pretty new to this, my skills are more computer based, and theres not a lot of information straight up on SSM
You might need to pull up further, its under a floor of metal that is bolted down to protect the ECU.. the wires runs towards the right towards transmission tunnel.
