ej22 problems
Posted: Mon Apr 26, 2010 2:33 pm
by Josho
hey guys having a few problems with my motor its a 94 ej22 under full throttle just misses i thought maybe could have been plugs leads so changed all this and also air filter and oil/oil filter moter accelarates hard and fine if i keep 3/4 throttle car then wants to stall at low idel also any help would be great thanks
Josh.
Posted: Mon Apr 26, 2010 8:46 pm
by AlpineRaven
can you explain a bit more, is it automatic or manual? is it a Liberty?
Posted: Tue Apr 27, 2010 9:09 am
by RSR 555
I had this just the other day.. Check to see if all the breather pipes to the intake are connected.. especially look at the one that goes to the Air Bypass Valve which is just to the divers side of the throttle body.
Posted: Tue Apr 27, 2010 9:33 am
by AlpineRaven
RSR 555 wrote:I had this just the other day.. Check to see if all the breather pipes to the intake are connected.. especially look at the one that goes to the Air Bypass Valve which is just to the divers side of the throttle body.
It would be causing stalling problems at idle..
Posted: Tue Apr 27, 2010 9:35 am
by RSR 555
AlpineRaven wrote:It would be causing stalling problems at idle..
Yep.. which is the symtoms he is getting
Posted: Mon May 03, 2010 2:27 pm
by Josho
thanks guys been working in brissy last week so filled up a full tank of ultimate and gave it a good run through seems to be running fine for now maybe dirty injectors not sure
its a manual 89 l series with a ej22 AP
