L-Series Speedos
Posted: Thu Mar 09, 2006 6:41 pm
by wrx_nut
can you wind the odomoter back on an L-series speedo?
Im interested as i am converting to ea82t, & putting the turbo dash in and would like the same reading as what the old dash was.....
cheers :D
wrx_nut
Posted: Thu Mar 09, 2006 6:55 pm
by Chris_Rogers
yes it can be done. pop it apart,pop the dial out, set it, put it back in. did the same thing to a sherpa dash years ago ( it reads '0' as I rebuilt the car.)
Re: L-series speedo's
Posted: Thu Mar 09, 2006 6:57 pm
by Fang
I just received one from NZ today - a RX turbo dash (diff lock, etc) it has 192k on it. The same one in my car now has 107k
Only paid NZ$25 for the dash - finding one of similar kms might be the way to go.
Posted: Thu Mar 09, 2006 7:04 pm
by Chris_Rogers
fang,
run it by and I'll set it for you.
Posted: Fri Mar 10, 2006 8:32 am
by wrx_nut
thanks...might pop it out and give it a go
cheers :D
Posted: Mon Mar 27, 2006 5:18 pm
by wrx_nut
ive just lifted my L series 3" and now the speedo cable doesnt reach....which one should i get so it reaches and fits..?
cant find the post of the discussion of the different speedo cables...
cheers
wrx_nut
Posted: Tue Mar 28, 2006 7:37 am
by Subaman
One from an L Series automatic will do the trick :wink:
Posted: Tue Mar 28, 2006 3:00 pm
by smoov
failing that, an auto MY one will also do too 8)
Posted: Tue Mar 28, 2006 7:01 pm
by wrx_nut
cheers....might go to the wreckers
:D
Posted: Mon May 01, 2006 6:10 pm
by wrx_nut
got one from a ea81 Leone front wheel drive
fits with a bit of left over length..
perfect for an L with a 3" lift
