Page 1 of 2
EZ30R Off Road Forester.
Posted: Tue Apr 13, 2010 6:34 pm
by jzk25
Recently finished this conversion on an offroad oriented SF Foz. We'd previously converted it from 2.0l auto to 2.5l manual and it was used and abused for a couple of years until the radiator split and the engine was destroyed. The owner was keen for a H6 conversion.
We originally ordered an EZ30D halfcut from sku81 but it missed the boat and he instead had a gen 4 EZ30R so we went with that. I attempted to get the factory ecu running the engine on the ground but the lack of CAN communication with other systems shut down the electronic throttle control so it wasn't usable.
Here's the setup on the floor.
We then decided to use a Vipec V88 instead. We'd already used one on another EZ30R conversion and they are an impressive ecu. Because I had already stripped the engine wiring out of the main loom I got a plug and pin set for the Vipec instead of a flying loom and reterminated the factory loom to suit the V88. Throttle body is AU falcon to replace the DBW as it bolts straight on and has built in 2 wire PWM idle motor that owrks great with the Vipec.
The ecu was mounted in the glovebox because there have been previous drownings of ecu's in offroad excursions. I used a genuine Motec mounting kit for the ecu.
I made a new exhaust for the car also to both quieten it and gain ground clearance. It turned out to be the best sounding H6 I have heard.
In progress.
Finished.
The car.
Posted: Tue Apr 13, 2010 6:52 pm
by riksta
very nice job mate, I like what you have done with the exhaust putting the exit out the bottom of the rear bar, I like it.
The hole car liiks good, hope you have some good trips in it now after all that hard work you have put in.
Rik.
Posted: Tue Apr 13, 2010 7:04 pm
by SKT
riksta wrote:
The hole car looks good, hope you have some good trips in it now after all that hard work you have put in.
Rik.
Oh I will.........
Lovin it Al. Obviously still needs the tune. Got it booked for a bash guard... right back to cover the O2 sensors and gearbox. Has a bit of poke to say the least. And smooth... talk about smooth... 1st with the Scorpion Low is trippy....
Can't rave about Al's work enough people
Posted: Tue Apr 13, 2010 7:23 pm
by D3V1L
well done guys...effort and a half!!
have to see it out in the dunes sooo much power...i can imagine the roost it will be throwing up:D
davo
Posted: Tue Apr 13, 2010 8:02 pm
by TOONGA
nice work there, did you use the transmission that was attached to it or mate it to the forester one?
Posted: Tue Apr 13, 2010 8:26 pm
by jzk25
The box is 03SG forester gears inside a 99SF case with scorpion low range gears. The SG case suffered some damage from a circlip failure so I replaced the case. The SG gearing is spot on for the H6 for road use, maybe a little high geared for offroad though but Scott can be the judge of that. Clutch is an Exedy FJK7005HD.
This car has got me excited about EZ30's again, fkn great engine. The Vipec(rebadged Link) ecu is also brilliant, you would not know it isn't a factory ecu.
Posted: Tue Apr 13, 2010 8:35 pm
by AlpineRaven
Awesome project.... As Toonga said above - im interested know what box you have...
H6 = dual range manual transmission - nice grunty combo!
Posted: Tue Apr 13, 2010 9:12 pm
by Alex
mother****er!
youre a crazy man hahaha
very very very niice :P
Posted: Tue Apr 13, 2010 9:33 pm
by Subafury
OMG yes. H6 POWAH!! this car just keeps getting better and better
Posted: Tue Apr 13, 2010 11:03 pm
by subasurf
You da man scott!!!
We had talked about this at some stage before you left. Never thought you'd ever get it done
Impressive! Pitty you aint here in Perth to show me it in person
I might have to drive on over
EDIT: Get that beast on a dyno
I wanna see the torque curve haha
Posted: Wed Apr 14, 2010 8:21 am
by vincentvega
awesome Al. thats the best offroad exhaust I have seen. I asked the exhaust shop to tuck mine up high and they didnt get half the clearance you have.
SKT: got a video of the engine note?
Posted: Wed Apr 14, 2010 8:56 am
by discopotato03
The word on the street is that Vipecs are really good and make the idle and low speed stuff better than factory if tuned properly .
Not a cheap exercise so someone really likes their Subie .
Cheers A .
Posted: Wed Apr 14, 2010 1:07 pm
by frogstar7055
Very nice,looks like it came from the factory that way.
Posted: Wed Apr 14, 2010 4:24 pm
by SKT
The car is going in for a tune in the next week or so. I will ask for a before and after print out of the output. I am interested to see exactly where in the range he can put the ponys for me....
I will get some vid of the note... Prob screamin down a dune
Either way I'll get somethin up soon.... The bash plate gets customed up on monday so once that is done I'll get some pics of that up too... Prob lost abotu an inch with the crazy arse headers.... Ah well... I'll just have to wheel stand everywhere
Posted: Wed Apr 14, 2010 6:00 pm
by Venom
Love it. Definitely some advantages in taking a foz off-road, like off the shell front and rear bars. Some more pictures of that exhaust would be great, something to shop the local shops how to do it next time i ask!
Posted: Wed Apr 14, 2010 6:11 pm
by clarkey
SKT wrote:The car is going in for a tune in the next week or so. I will ask for a before and after print out of the output. I am interested to see exactly where in the range he can put the ponys for me....
any chance that we can find out how much it all cost?? and that looks Big, how big springs did you put in it?? i wanna do a conv on my 05 foz, i want it higher too.
Cheers Mike.
Posted: Wed Apr 14, 2010 6:23 pm
by 2jz929
Awesome conversion Al, would definitely be in on it if i didnt have the XT. Now post it up on PF!!!
Posted: Wed Apr 14, 2010 8:41 pm
by dibs
gives me mad thoughts where did you get the spare carrier???????????????????
dibs
Posted: Wed Apr 14, 2010 8:58 pm
by SKT
dibs wrote:where did you get the spare carrier???????????????????
dibs
Its a Subaxtreme rear bar.... Snagged it on ebay for like $350.... splash of paint etc....
Posted: Thu Apr 15, 2010 4:49 pm
by SKT
clarkey wrote:how big springs did you put in it?? i wanna do a conv on my 05 foz
Cheers Mike.
I've gone with raised Kings.
As a matter of fact. I've got a slightly stiffer pair of rears in my shed that would fit your car for sale. Brand new in the plastic with reciept.... I got a stock number of an owner of a later model Foz only to find out they wont fit mine. I'm pretty keen to move them on if you wanna PM me and talk $$$.... All you'd have to do is get the fronts and roll it into your local suspension mob and in under a few hours you'd have a spring lift. Its a good start without going the whole strut and body lift.
