Smokey Subaru!
jimmeh14
Smokey Subaru!
Post by jimmeh14 » Wed Feb 17, 2010 9:35 pm
Hey all,
Today i finished building my subaru :D.
Its a Subaru Liberty '95 and had to replace the engine with another EJ22.
Finally got it working, only to find out that theres ALOT of white smoke coming out of the exhaust and a bit of water too.
Not sure if i connected something wrong orr what?
The oxygen sensor got cut so i soldered it back together but i don't think that could be the problem?
help??
Kappage
Post by Kappage » Wed Feb 17, 2010 10:11 pm
head gasket.
jimmeh14
Post by jimmeh14 » Wed Feb 17, 2010 11:01 pm
nope i know it's not a head-gasket cause I replaced them both with brand new ones.
Kappage
Post by Kappage » Wed Feb 17, 2010 11:10 pm
Well it sounds like your leaking water into your head some where. hence the white smoke.
Post by TOONGA » Wed Feb 17, 2010 11:39 pm
could be excess water in the exhaust system from when the engine was out of the engine bay but it does sound like water is getting into the exhaust some how
have you done a compresion test on the motor since it started smoking
Post by steptoe » Thu Feb 18, 2010 8:17 am
auto? if so and they have diaphgragm cannister on side and sucks auto fluid that burns white like water does. Are you losing water? Valve guides or stem seals checked or replaced when head gaskets done?
O2 sensors not meant to be connected with solder, just crimping devices
Post by El_Freddo » Thu Feb 18, 2010 3:38 pm
The real question to ask is: Have you had it up to running temp for some time (like 5 or 10 minutes)? If not, what you're looking at could be exhaust vapour - my EJ did it for some time after not being started in I don't know how long. That was also during the moist time of the year where vapours are easily visable.
I'd still check out that diaphram that steptoe mentioned.
jimmeh14
Post by jimmeh14 » Thu Feb 18, 2010 9:13 pm
Nah my car is manual.
The engine was put in it round about last year say... october and i've only been able to start it on tuesday... but i got the engine from a wrecker so who knows how long its just been sitting there! I'll try just letting it idle for a 10 minutes.
I've been told that when you remove the exhaust manifold from the heads, oil etc can enter into the catalytic converter and cause it to smoke and it could take weeks even to remove it completely but by then the O2 sensor would be gone?
