EA82T boost limit
H-top
EA82T boost limit
Post by H-top » Mon Dec 14, 2009 7:34 pm
G'day,
im now new to EA82T's.
what kind of boost is the engine and computer
able to deal with?
engine with these specs.
EA82T Spider 4 Plug
RS lib WAIC
TD04
split pulse dump pipe
2.5inch exhaust
hi flo air filter
all else standard
338k on the clock with reco'd heads
Sam
H-Top
rolling in
nncoolg
Post by nncoolg » Mon Dec 14, 2009 8:21 pm
...steady-on mate, only picked her up saturday!
# EA82 AWD 4EAT,
H-top
Post by H-top » Mon Dec 14, 2009 9:17 pm
Well i've already got all the bits ready to go in right now :)
H-Top
rolling in
Willie
Post by Willie » Tue Dec 15, 2009 9:48 am
I've heard of people trying to force about 13 PSI into them - they don't tend to last too long like that. Just a small amount of extra boost, bigger exhaust and a good IC will see reliable improvement.
If you want big power, it will be easier and cheaper in the long run to do an EJ20T conversion, IMO.
Willie.
Canberra
MY06 Forester XT Luxury
MY05 Pajero Exceed DiD
1975 VW L Bug (1303)
Post by Gannon » Tue Dec 15, 2009 4:46 pm
I ran 10psi for over a year with no i'll problems. And when the headgasket blew from a dodgy fan wire, the pistons were fine.
Saying that, i wouldn't push the stock engine and ecu past 10psi if you want it to last any amount of time. I also always ran 98 while i had it at 10.
H-top
Post by H-top » Tue Dec 15, 2009 6:26 pm
Suparoo how effective did you find the waic? And what pump and fluid did you use
H-Top
rolling in
Post by Gannon » Tue Dec 15, 2009 6:35 pm
I cant say exactly how effective the intercooler was because i upgraded to a TF035 and 2.25" dump pipe at the same time. I have seen a dyno graph of before and after top mount intercooler on an EA82T and there was a nearly 10ft.lb off torque increase at about 3600rpm. This can be put down to an increase in ignition timing because of the cooler air charge
I used the stock pump and for coolant i used the same stuff i use in the engine. Pure water has the best heat capacity but i like the anti corrosion protection of the coolant.
H-top
Post by H-top » Tue Dec 15, 2009 6:48 pm
I've got a heat transfer and cooler but am looking for a pump for it.
H-Top
rolling in
H-top
Post by H-top » Tue Dec 15, 2009 6:49 pm
It definately sounds like a must do!
H-Top
rolling in
Suby Wan Kenobi
Post by Suby Wan Kenobi » Tue Dec 15, 2009 7:59 pm
I ran my EA82T with 17psi. I have an WAIC, the engine had about 16000kms on it after full reco and lasted that way for about 12months before it let go. I didnt drive it at full boost everywhere during that time but i gave it a boot full every now and then.
The long road ahead
Xtreme_RX
Post by Xtreme_RX » Tue Dec 15, 2009 7:59 pm
I ran 14PSI for over 3 years on my RX. It was fitted with a WRX air to air IC.
12 PSI is ok provided you have an IC.
http://www.subiparts.com.au
0438 887 746
subarooster
Post by subarooster » Tue Dec 15, 2009 8:31 pm
17 Psi! whoa :)
01' Liberty B4.
H-top
Post by H-top » Tue Dec 15, 2009 8:31 pm
on stock turbo?
H-Top
rolling in
Post by Gannon » Tue Dec 15, 2009 9:53 pm
It all comes down to 3 things........
Cheap, Powerful and Reliable......
choose 2.
Subaman
Post by Subaman » Wed Dec 16, 2009 10:24 am
I`ve had two RX`s and ran both of them on 15psi for years without out any problems. Had a TT Legacy AIR/AIR intercooler, dont bother fitting an EJ just for reliabilty reasons as they will give you just as many if not more problems as the EA in the long run. Just dont expect to turn the boost up on tired old head gaskets and expect them to last for ever. ;)
H-top
Post by H-top » Sun Dec 20, 2009 9:39 am
that pretty good, i'm feeling there is hope for me yet!
Sam
H-Top
rolling in
H-top
Post by H-top » Sun Dec 20, 2009 9:40 am
subaru leone
H-Top
rolling in
