hi guys snew
been a wile.we moved to glassy works hectic bla bla bla.
i have a ? would a 91 2.2 lib box fit a 99 outback or how much would you pay for a outback box .found 1 with a chiped tooth in center diff good price
gunna have heaps for sale after xmas puttin brumby back on road std .
ps still got the rex gunna get della a outback for camping n fishing.
dibs
outback
Depends if you have an Outback with hydraulic clutch or not. A liberty gearbox would have cable operated clutch. You'd need to get all the cable and probably clutch pedal/pedalbox from the Liberty and put that into the Outback too - not sure if this is easy but anything is possible.
If the Outback has cable operated clutch then this may not work straight off either if it's a little difference in how it works.
I just sold an Outback gearbox complete with clutch and everything for $250 in full working order. Trouble is they don't come up forsale too often. But if the Outback is cheap enough get it, you should be able to get some kind of gearbox in it without too much messing around. Where there's a will there's a way!
