Sorting out my fuel system
Posted: Wed Nov 18, 2009 3:11 pm
Hey guys,
When i had my EJ conversion i was advised to install a pre-pump, swirl pot and a VL turbo (or equivilent) fuel pump. That is all installed in the car currently and i certainly don't have any problems with fuel delivery to the EJ. What i wasn't happy with were two lines running under the car, as i was told they wouldn't fit were the existing fuel lines already run. I am fairly sure now that's not true, and it was done becaue they were extremely busy and my car was taking up too much time/space in their workshop.
18 months later and i'm actually getting off my arse to have a look at those two lines. Closer inspection reveals that one is the wiring for both the efi pump and the pre-pump. Pretty sure this will be easy to redirect through the car body and out of harms way were it is now. what i can't work out is what the other fuel line is for. I have traced all the other hoses at the surge tank and accounted for inlet from the pre-pump/fuel tank, return line to fuel tank, outlet to the EFI pump. So i'm guessing that this other line is a return directly from the injector rail to the swirl pot. Am i correct?
If it is a injector rail to swirl pot return line is there anything stopping me from switching this to the old carby return line to the fuel tank?
I am also considering fitting an EFI fuel tank. If i did could i run the efi pump directly from the in-tank feed and do away with the swirl pot setup completely?
Rhys
Rhys
