02 sensors and were to buy
chubby37
Post by chubby37 » Thu Nov 05, 2009 11:51 pm
where is the best place to buy 02 sensors for a GT legacy and anyone know prices?......could be the same as early wrx????..i,m not sure
Post by AndrewT » Fri Nov 06, 2009 12:27 am
yeah same as early wrx pretty sure. U can get generic ones off Ebay for about 50 bucks, most people rekon they work fine. Genuine Subaru pretty expensive...maybe FROG can post up a part number and price though.
chubby37
Post by chubby37 » Fri Nov 06, 2009 1:09 am
ok thanks.............
Captain Obvious
Post by Captain Obvious » Fri Nov 06, 2009 6:46 am
bill, you will need a 3wire one for you car, and a generic one is as good as any. what problems you having?
bryan
chubby37
Post by chubby37 » Fri Nov 06, 2009 8:25 am
mainly very very heavy fuel usage,down on power,off on response but mostly the fuel to the piont you can smell it real bad on idle but if you put your foot down it pours out fuel smoke.....be lucky to get 200k,s a tank
Post by AlpineRaven » Fri Nov 06, 2009 11:27 am
mate.. Buy it off ebay. Get them from america if need to. Sounds like it could be O2 sensor. Maybe coolant sensor & knock sensor might be worth replacing.
FROG
Post by FROG » Fri Nov 06, 2009 1:59 pm
AndrewT wrote:...maybe FROG can post up a part number and price though.
arm and a leg required :rolleyes:
Captain Obvious
Post by Captain Obvious » Fri Nov 06, 2009 8:01 pm
What alpine said bill could be any of them, i would start with pulling the coolant sensor and cleaning it, then move the knock sensor up onto the rubber mount that the WAIC mounts to!! if problem still persists see your doctor...... oh what that if your taking pain killers my Bad!!!
but really failing all that it will be O2 sensor or poss injectors.
chubby37
Post by chubby37 » Fri Nov 06, 2009 11:43 pm
ok i,ll give those things a go over the weekend
Leo
Post by Leo » Mon Nov 09, 2009 12:10 pm
my o2 sensor's stuffed in my wrx motor too. i've got all those problems you mentioned. only getting 250 k's per tank, very fumey, low power, not very responsive plus heaps more! i've tried to find one on ebay but the only one on there is $275. let me know how you go with it
cheers, leo
