newest member
Posted: Sat Aug 29, 2009 2:01 pm
I just got a subaru liberty awd and would like to give an extended hello to everyone. Thanks for all the people who gave me advice on my advice post. Im really loving this car and look forward to hopefully going on some cruises if you guys do any.
A couple of quick questions though on things i need to sort out.
1) my reverse lights arent working (its a manual). i have checked the globes and they seem fine and the fuse (dash) which is shared with the indicators seems fine as well (tried switching it anyways although it looked fine). Any ideas what else this could be before i start probing around with a multimeter?
2) I will need to replace one of my cv boots. any idea how much this will cost (i guess i will probably replace both as the other is likely on its way as well if one side is gone). The cv shaft/joint itself is not noisy so it should only need the boot replaced.
3) The reverse gear seems to be really easy to crunch, even from a standstill when i shift it into reverse, unless i shift really slow it will crunch when engaging. Is this normal? would it most likely just need a fluid change?
4) I will get a good first service done soon and will replace all fluids filters etc. and would like to know what oil you guys would recommend? i dont want el cheapo stuff but on that note i dont want to go crazy and spend $70 on oil either, i used to spend around 40 for mid-range performance stuff on my old car. and what weight is recommended as well? i was thinkinga decent 10W40 like penrite.
gerzod
gerzod
