EA82 T belt cases always stuffed....
What is it with the back timing belt cases, of EA82's? They are always stuffed, whether they have had the captive thread ripped out due to seized thread or drilled out for same reason and been broken, and/or they have melted due to overheating. The meltdown makes for trouble lining up timing marks and fit back to the engine or possible belt clearance on reasembly. Do EJ's suffer similar fate?
- discopotato03
would be caused by over tighten, EJ doesn't seem to have a problem.
- FROG
unless they've overheated....
ea doesn't matter if the belt slips, but the ej i pondered about off roading and belt slip.... some one mentioned the boys in the US driving them through mud with no problems and i didn't care to research it. fine atm and my engine bay has recived lots of dirt and lately water (cant ignore a huge puddle or two)
- SCOOBIDOO
WOW thats awsome, you must get really good econnomy woth no belts on your engine...hahashuffbag wrote:ha i dont have belts on either of my engines ej and ea for the same reason. on the ea the timing mark is in the exact position (from the top of my head) were the rocker cover meets the cam box, the slight gap were you can see the gasket is what i use.
THE FASTER THE SPEED - THE BETTER THE IMPACT...SUBARU
After you decipher it! If you take it completely outta context you end up with this bold statement as SCOOBIDOO has used it:shuffbag wrote:im not going to edit it, you know what i was talking about
It does sound like quite a feat! Where can we get one of these? I did have a chuckle about it, its amazing what one word can do for a sentance:shuffbag wrote:ha i dont have belts on either of my engines ej and ea
shuffbag wrote:ha i dont have belt covers on either of my engines ej and ea
- discopotato03
Just a bit of trivia for those that choose the leave the middle belt cover off an EA82T engine .
On Sunday I decides to re-tension my belts because they look/feel a little loose after being replaced a few months ago .
I thinks no worries no middle cover to make life difficult - should be able to see/get at everything . Wrong
You can see from the top the drivers side tensioner bolt heads - if you go cross-eyed and resist the temptation to attack the PS pump .
The brace on the back of the AC elec fan j u s t doesn't allow enough space for a 3/8 dr torque wrench and short extension to get at one of them .
To get elec fan out other fans shroud has to come out and the lower 10mm headed bolts are a joy - aren't they .
The pass side tensioner bolts are even harder to see , don't bother with the lower one as only the digital eyes feel it .
Not enough swing again with torque wrench so off with the splash/bash guard and that steel plate EA82Ts use to insulate the headers heat I reckon .
I turns engine over by hand to put tension on the belts and cracks the tensioner bolts so under their springs load they pull in any slack on the slack sides of the belts . They both moved and their bolts were tensioned up to the factory spec which from memory is 20 Nm /14.8 ft lbs but check that .
It sounds a little quieter again so something gained I suppose .
Cheers A .
Cheers A .
