simple mods for the '93 legacy ?
stinky
Post by stinky » Sun May 31, 2009 1:34 am
Trying to think of a few simple things I can do to the legacy... it's got the ej22 under it.
What's a good exhaust profile to use to get a good note and some easy flowing?
what suspension can I swap in to get a big more height, I think you use the outback springs right?
how hard is it to replace lights in the dash ( the ones behind fuel guage etc are dim or blown ) ?
what's a good headlight upgrade ( they're a bit dim ).
anything else that's cheap and worth doing? remembering that it's legal to do just about anything to a car here :D
Post by AlpineRaven » Sun May 31, 2009 9:50 pm
stinky wrote:Trying to think of a few simple things I can do to the legacy... it's got the ej22 under it.
EJ22 isn't really worth mucking around with to gain better power output... thats my opinion and i've heard guys spending over a grand trying to improve power output on EJ22 and getting nowhere...
Suspension - yes outback struts & outback trailing arms mounts/blocks etc. Springs are the same between Liberty/Legacy & Outback so you'll need raised coils to get extra 1".
Globes - easy, there is phillips head screws around the surround, undo them, there is about 4 more screws holding the cluster in, and remove the cluster, behind them there is small notches that holds globes in them, sometimes these globes has a coloured sleeve - i recommend you to remove them as they're crap and takes out a lot of lighting.
Headlights - not much you can do with them, they're always like that, have a look at the reflecter, it could be 'worn' down/faded - two options is to get good set or get it re-chromed - can't help in America.. Otherwise you could add external full beam lights.
exhaust.. can't help much as i haven't done anything, some people have done 2" flow thru.. but others have their own opinion.
edit - you could try which I havent done before with dim headlights is to re-wire with relays and direct from battery?
Captain Obvious
Post by Captain Obvious » Mon Jun 01, 2009 5:41 am
Yes outback struts and springs are what you want, search on here and you will find the part numbers you want 96-98 outback!! that ej22 can sound very good with a nice sports muffler on the back end so maybe look in to that!!
didnt think it would take long for you to get the modding bug!
Bryan
