Make: subaru
No. Doors 3
Seat Capacitiy 2
Transmission Manual
Gear Location Floor
Drive Front Wheel Drive
Fuel Type Petrol
Release Year 1984
Country of origin JAPAN
Dimensions: matchbox car
Kerb Weight (kg) 555
Gross Vehicle Mass (kg) 980
Wheel Base (mm) 2295
Length (mm) 3195
Width (mm) 1395
Height (mm) 1420
Track Front (mm) 1220
Track Rear (mm) 1220
Engine: massive
Engine Location Front
Configuration In-line
Engine Size (cc) 665
Cam Overhead Cam
Engine Cycle 4 Stroke
Engine Type Piston
Cylinders 2
Valves per Cylinder 2
Compression Ratio 9.5
Power 27kW @ 6000rpm
Torque 54Nm @ 3000-3000rpm
Induction System Aspirated
Fuel: oily rag
Fuel Tank Capacity (litres) 32
Fuel Delivery Carburettor Single
Method of Delivery Mechanical
Other Options: respect points
sounds system: Sony head unit
fusion 6" speakers
Interior: seatcovers (yes colour coded)
Exterior:
SUNROOF! HOW AWESOME!
13 inch gemini rims 155/65 R13
exhaust tip that look poxy
poor window tint that needs replacing
