EA82T and mpfi alert welch plug
Post by steptoe » Mon Mar 23, 2009 10:42 pm
Just as I was fitting flywheel to my EA82T I noticed a little welch plug of about 10mm in the rear of the inlet manifold on the bolt on bit at the back easily visible from the flywheel view.
It was turning a rusty brown as in rust through sort of thing.
I have jammed it ull of epoxy until further notice.
Just thought it worth an alert to check it with a mirror on you EA82T's and mpfi to save grief at a later date. What is worse is there is two plugs in same spot one is a little bigger. I think there are a few more of these welch plugs on these manifolds. Well worth checking me thinks
Post by El_Freddo » Mon Mar 23, 2009 11:02 pm
Yeah seen them but have never seen one leaking - thought they were brass...
Good heads up though ;)
Subaman
Post by Subaman » Tue Mar 24, 2009 7:27 am
I have had one leak, luckily had a spare manifold at the time.;)
