Post
by Alex » Tue Feb 17, 2009 2:14 pm
is 17's a typo?
also, its not just gearing youd have to think about. Larger/heavier tyres place much more stress on the whole car. Gearbox, cv's, brakes, everything suffers much more.
at the moment im running 29 inch tyres on 15inch rims. this is largest id ever go on a l-series. They also arent an option if you plan on running the standard motor. You will require alot more power to get them rolling, and keep them rolling. To fit 29s it also takes alot of work to cut guards and youd need at least a 3inch lift.
Give us sum specs of your car and we can give you better advice.
