EJ to VW adaptor kit
Post by D3V1L » Mon Nov 03, 2008 8:21 pm
hey guys, does anybody here know anything about the adaptor plate and flywheel kits for fitting EJ motors to VW engines?
im confident i can make the actual adaptor plate, but the flywheel is a different story
i know u can buy kits but for the mammoth amount of money i just cant justify it on my buggy. ANY help would be appreciated as ive got a subaru motor to put into my buggy and really want to get this happening. and this adaptor plate and flyuwheel are the only 2 things now holding me back
cheers
dave
Post by RSR 555 » Mon Nov 03, 2008 10:38 pm
Hey Dave
Do you know Chris, who lives in Banjup? cause I brought a adapter kit from him years ago for a EJ into a late model VW van (caravelle?? or something to that nature) and it wasn't that expensive and seemed to do the job just fine.
chriSTIan
Post by chriSTIan » Mon Nov 03, 2008 10:46 pm
Basically what he does is cut the centre out of the ej flywheel and welds it in place of the vw centre or somethig like that..
Cam
Post by Cam » Mon Nov 03, 2008 10:48 pm
Vw flywheel and clutch, redrill the vw flywheel to suit the subaru bolt pattern and put a spacer the same thickness as the adapter plate between it and the crank which i think is needed(?) And balance, i think thats it...
jzk25
Post by jzk25 » Tue Nov 04, 2008 6:59 am
Volks conversions on the Gold Coast. John Sherman has been making them since the 60's.
http://www.volksconversions.com.au/
You usually need to run a 215mm kombi clutch or paddle type 200mm in a beetle chassis with an EJ22 or slippage ensues, even in a buggy.
Here's a buggy I did an EJ22 conversion on 6 months ago.
http://s65.photobucket.com/albums/h219/AL_RS/Buggy/
You also need a short sump and to fabricate a rear bar that incorporates engine mounting as the beetle box mounts are not sufficient to handle an EJ22. Cooling system is a lot of work also.
Cheer. Al.
Post by D3V1L » Tue Nov 04, 2008 7:09 am
i know about the entire process and whats needed heheeheh...all i need to find is a flyuwheel thats been already modified...seems to be more of a pain in the ass then its worth....
dave
jzk25
Post by jzk25 » Tue Nov 04, 2008 7:26 am
You could go crazy and just buy one. Seems to work out well for most people. ;)
Cheer. Al.
Post by D3V1L » Tue Nov 04, 2008 8:02 pm
yeh man....$1600 for a custom flywheel is the way to go on a buggy that cost me $1000 ;)
its ok guys i found a guy in QLD that will sell me the whole kit for $500 which is the cheapes ive found so ill go with that
subaru powered buggy here we come!
