air intake kits
clarkey
air intake kits
Post by clarkey » Thu Oct 16, 2008 6:01 pm
hi all
im looking for a air conversion kit for my gen 2 rx lib. i am just wondering if some one could help me with telling me if a any air intake kits will fit or if i have to get a liberty kit???? my mate that i work with has just asked me to find out because he is helping me find one for my car.
cheers Michael.
nuthin beats a subbi
Post by Gannon » Thu Oct 16, 2008 8:48 pm
Im gonna assume that you are talking about a air filter replacement.
Although the common thing to do at the moment is fit a pod filter on the end of the MAF, but i wouldnt bother.
You'll loose more performance from sucking in hot engine bay air that you will achieve from the slight reduction in restriction.
Post by Alex » Thu Oct 16, 2008 9:07 pm
if you wanna do an upgrade just axe all the resonating boxes. Thats about all thatll make a difference. Even then you wont feel it. Itll just make more noise haha.
Post by AlpineRaven » Thu Oct 16, 2008 10:40 pm
Been there done that... waste of time - I'm being honest with you. Only thing is the noises but performance wise isnt much improvement.
clarkey
Post by clarkey » Fri Oct 17, 2008 4:12 pm
yeh. i was aiming more towards a dry filter. really all i wanted to know is if the libs were the same size as a wrx or somthing. if i could use one made fo a wrx i want a bit better sound ill do other things for performance.
cheers
Michael.
Post by RSR 555 » Sat Oct 18, 2008 1:04 am
I once saw a bloke remove the shitty ressy box from inside the guard and replace that with a made-up pvc piping upto the standard airbox and then feplace the air filter with a K&N (or I'd use the factory STi filter pad), this on the dyno had the same results as a APS cold air intake.
Post by AndrewT » Sat Oct 18, 2008 10:45 am
yeah aren't these APS kits just really a piece of pipe anyway?
Post by RSR 555 » Sun Oct 19, 2008 1:09 am
yeh but at a cost of $550 it's a bit exxy...
And the way this guy did it, it still looked factory once you lifted the bonnet :) no permits from licence dept. required and it leaves your filter pad high away from the chances of getting wet ;)
Not saying this is the ideal way but quiet effective at a small cost.
RetroLover
Post by RetroLover » Thu Oct 23, 2008 3:47 am
Suparoo wrote:Im gonna assume that you are talking about a air filter replacement.
I was seriously going to do this for my Liberty as i did the same this for the Leone. But seeing this reply and some of the other reply's on this thread i now will probably not do this. The Leone sounded awesome with the POD though, but then again it did take a shit load of the hot air from the engine, and you did noticed servier loss of engine power on those hot stinking days.
Might just take the resignator off, that'll make a bit more of responsive peformance out of the engine. Anybody tried this before?
Post by Gannon » Thu Oct 23, 2008 5:21 am
If you mean the resonator in the guard, maybe a little lift in performance. But it will get a lot more induction noise, similar to when you had ya pod filter.
RetroLover
Post by RetroLover » Thu Oct 23, 2008 5:37 am
Im fine with more induction noise. The EA82 sounded killer with a POD on it, im sure the EJ22 will sound even more beefier. The ponsy chardonnay sippers around my mates place enjoyed the sound of my last subi engine roaring down the street with the POD and all, maybe they'll like to here the EJ22 as well, lol. I might do that when i have some proper time to do more work on the Liberty.
BTW nice Avatar. Be one sweet Brumby uprgade if it ever where to go into full production.
Chrus
Post by Chrus » Thu Oct 23, 2008 1:35 pm
RSR 555 wrote:I once saw a bloke remove the shitty ressy box from inside the guard and replace that with a made-up pvc piping upto the standard airbox and then replace the air filter with a K&N (or I'd use the factory STi filter pad), this on the dyno had the same results as a APS cold air intake.
Ha ha Paul, are you taking about me?
The setup works well IMO, because your still employing the stock air box and ducting cooler air in from the front of the car.
IMO I would only use a pod with a heat shield of some design, and then you really only need them on cars with rotated turbos making big powah :cool:
MY05 WRX STI Spec C Type Ra
MY05 Legacy Outback LLBean
89 Legacy RS Turbo
Post by RSR 555 » Fri Oct 24, 2008 7:34 am
Chrus wrote:Ha ha Paul, are you taking about me?
;) geez buddy.. how did you know that? lol
For sure there's a little more induction noise but please, the sound of it that noise.. gives any revhead half a b...r ;)
