Page 1 of 2
TT has taken on a new life .....
Posted: Tue Jan 24, 2006 1:23 pm
by legacytt
After a lttle work the transformation has occurred and what was once the perfect sleeper road cruising wagon is now the ultimate offroad voyager. Apologies for the dark photo.
It started life as a Heritage and was converted to TT around 3 years ago. It now has a 3 inch lift, 16 inch Forester GT Rims and 215/70 BFG AT's finish it off nicely. Next is a Lib dual range with L series low as the Aus Spec RS turbo gearing in it now is a bit too tall.
Posted: Tue Jan 24, 2006 2:29 pm
by wrx_nut
nice ride mate... were you in lorne about 2 weeks ago.. or near lorne in victoria?
i swear i saw a lifted soob like that!
Posted: Tue Jan 24, 2006 2:31 pm
by Fatz
truly amazing
Posted: Tue Jan 24, 2006 2:39 pm
by bluesteel
nice work ian...
shame you wont be there when i come through on the weekend
TT Lift
Posted: Tue Jan 24, 2006 2:47 pm
by legacytt
Sorry wasn't in Lorne, has only been in Tas in this form so far. Keen to catch up with all the Tassie boys for an offroad trip, now that I can keep up with you without tearing parts off the underside. Is the monster going yet Johnny?
Posted: Tue Jan 24, 2006 4:44 pm
by vincentvega
kickas Ian. nice work
what suspension you running?
Posted: Tue Jan 24, 2006 4:46 pm
by bluesteel
umm...
nearly, been a bit slack lately and havin a few issues with the twagon that ive had to sort out
cant be too far off now tho
Posted: Tue Jan 24, 2006 4:48 pm
by Fatz
lorne?? launnie in tas u mean?
suspension is raised king springs(sorry to steal ya heat ian)
Posted: Tue Jan 24, 2006 5:44 pm
by smoov
pfffwoooaaarrrr!!!!!
why not an auto, may i ask??
Posted: Tue Jan 24, 2006 7:20 pm
by seagull
Yes Ian please give us a run down on the springs struts you are using .
did you just use a 75mm body lift not a sring tower lift as well ?
did you purchase the body lift or make it your self .
I am doing the same to my wagon in Perth , so interested in your build up .
Looks the part from were I am sitting .
seagull
Posted: Tue Jan 24, 2006 7:32 pm
by BaronVonChickenPants
Looks very very nice, looks like you'll have plenty of fun with it.
Amy reckons it needs bigger wheels and tyres, it's entirely possible I'm a bad influence
Jordan.
Posted: Tue Jan 24, 2006 9:25 pm
by MUDRAT
That really is a masterpiece. Well done.
Lib
Posted: Wed Jan 25, 2006 7:37 am
by legacytt
Thanks for all the positive comments folks. It is a 3 inch lift, Outback Struts, Kings raised springs and Outback rear swing arm mounts. Car used to be auto, so if the low range manual won't tow a heavy trailer in the bush I will revert to that again.
Posted: Wed Jan 25, 2006 8:26 am
by BRUMBERTY
Clap Clap Clap.
Ian, it looks fantastic.
To quote a famous Aussie actor...
"You've seen it, you've heard it........when do we go for a ride??"
How about Friendly Beaches or Central Highlands???
Isn't there a kick arse track up the Western Tiers from around Cressy?
I will be calling.
Posted: Wed Jan 25, 2006 11:39 am
by Suby Wan Kenobi
Looks a very neat package, the TTs work nice offroad with an auto if you havent considered it yet.
Posted: Sat Feb 11, 2006 12:59 am
by seagull
Is this running out back kings springs or liberty kings on the front ?
any one ? I am going shopping for these sat , seagull
Posted: Sat Feb 11, 2006 7:18 am
by vincentvega
early outback front and rear struts, with outback springs. Ian's are raised king springs, but you should choose between raised and standard height based on how high you need the front of your car..
(im not sure what parts you have used elsewhere)
Posted: Sat Feb 11, 2006 3:46 pm
by aspro
Id be proud to say i owned that.... real head turner. Well done.
Posted: Sat Feb 11, 2006 4:47 pm
by vidler
nearly makes me want 2 sell my L-series and start a project like that. very impressive
TT
Posted: Tue Feb 14, 2006 2:04 pm
by legacytt
It certainly has been turning heads and has received a lot of positve comments. Had a Landcruiser owner look under it and exclaim "It's got more clearance than the 'Cruiser, very inspirational, I want one"
I have put quite a few k's on it and am very impressed with the overall package. I have a Lib dual range, L series low range gears and a 4.11 front diff lined up on the bench. Now to merge them all together. It is definately geared far too tall as it is so this setup should make it do the job.
